Steering Column
Old November 14th, 2007, 07:25 PM   #1
99stangman is on a distinguished road
Smile
Steering Column
hi,
could someone please tell me how to remove the steering column, or direct me to a good site ( i cant find one). I have the air bag and main bolt off. My main objective is to remove the intermediate shaft, to enable me to get to the pedal assembly. It looks like its going to be a tough job now, and im beginning to think that i should have started from the engine side..... Any help would be appreciated.
Thanks
Old November 15th, 2007, 11:33 AM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
Originally Posted by 99stangman View Post
hi,
Thanks
You need to remove the air bag, steering wheel, and a device referred to as a clock spring (an electrical connector between the steering wheel and steering column). The steering should be in a straight ahead position before you remove the steering wheel. It needs to be in the same position when you reinstall the steering wheel and clock spring.
After that just remove the various plastic parts, disconnect various wiring connectors, disconnect the coupling at the bottom of the column, and there are 4 fasteners that hold the column in. There is also a cable from the auto trans that needs to be disconnected.
Old November 16th, 2007, 02:21 AM   #3
How are the hex screws that connect the column to the intermediate shaft removed. I cannot reach them. Also, is it possible to just disconect the shaft and column from the universal joint that connects the two, without removing EVERYTHING else? Ive tried this but i cant get the shaft out of the joint, even with the bolt undone. Use oil?
This is horrible
Old November 16th, 2007, 07:48 PM   #4
This is horrible
It's important to not turn the steering wheel very far in any one direction with the universal joint disconnected or the clock spring will be damaged. I believe the universal joint can be removed by itsself. I took the steering column out of mine a few years ago and don't remember a problem with that. I'll look at the shop manual this evening to refresh my memory.
Old November 16th, 2007, 11:02 PM   #5
The shop manual says the universal joint is removed by removing the two pinch bolts and sliding it out. I believe you can reach the bolts with a socket if you turn the steering wheel, but set it straight ahead before disconnecting it.
Old November 17th, 2007, 06:56 PM   #6
I got it out! Really wasnt that bad when I figured out what needed to be done. Thanks for the help stephen
Threads Similar to: Steering Column
POP in Steering 00GTstang 99-04 6 July 10th, 2007 10:52 PM
steering hmotes 5.0 Mustangs 1 June 5th, 2007 03:43 PM
Steering? 89five.0 5.0 Mustangs 8 May 27th, 2007 11:25 PM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 08:24 PM
Popping In Steering Column 4.6gtmarine 99-04 14 November 11th, 2006 05:33 PM
