Gear ratios?
Old November 15th, 2007, 06:28 PM   #1
RhadCundell's Avatar
RhadCundell is on a distinguished road
Send a message via AIM to RhadCundell
Gear ratios?
im jsut wondering what do the diffrent ratios do?
im sure its something liek make the car accel faster
Old November 15th, 2007, 06:34 PM   #2
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
a higher ratio (4.10:1) means the ring gear has (in ford cases) 41 teeth and the pinion gear has 10 teeth. this will accelerate the car by multiplying torque much faster than the stock 3.27:1 ratio.
Ring and Pinion Gears: The Ultimate Debate
ModdedAutos
1999 Mustang V6
Old November 15th, 2007, 06:37 PM   #3
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
^ what he said
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old November 15th, 2007, 06:38 PM   #4
thetrooper31 will become famous soon enough
Send a message via AIM to thetrooper31
[SIZE=5][COLOR=Yellow][/COLOR][/SIZE][COLOR=green]
[/COLOR]
Old November 15th, 2007, 06:39 PM   #5
Hip Hop Artist
Youngin's Avatar
Byebye V6~
Welcome Home New Pony :P
Youngin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of light
Send a message via AIM to Youngin
dont you lose top speed ?
ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig
http://www.myspace.com/moddedmustangz
Modded Mustang's Song
Old November 15th, 2007, 06:41 PM   #6
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
yes....
but u arent going to go 150 down the street..
i think it doesnt lose speed on stock bu idk
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old November 15th, 2007, 06:56 PM   #7
14.79 @ 92.15
These gears will affect your theoretical top speed, but not your actual top speed. You will be pulling harder in higher gears, so you will go just as fast, if not faster, with 4.10s over 3.27s
ModdedAutos
1999 Mustang V6
Old November 15th, 2007, 07:11 PM   #8
Hip Hop Artist
Youngin's Avatar
Byebye V6~
so why do people get 3.73 instead of just all 4.10 . im pretty sure theres a good reason but just wondering
Old November 15th, 2007, 07:35 PM   #9
14.79 @ 92.15
same reason some people get 4.30:1 instead of 4.10:1. some people think 3.73s get better mpg (they do, but not much), and some people (the smart ones) trap at the top of their top non-overdrive gear in the 1/4 at redline with that ratio.
i.e. i trap at 4500 rpms in 3rd in the 1/4. i redline at 6k rpms. ideally, i would have a gear such as 4.30:1 to trap closer to 5k-6k rpms range. that would net me a lower 1/4 mile time...
ModdedAutos
1999 Mustang V6
Old November 17th, 2007, 12:13 PM   #10
oasr87 is on a distinguished road
a 3.73 ratio will give you less torque compared to a 4.10 or 4.30... it just means that the pinion has to rotate 3.73 or 4.10... times for the ring gear to rotate once... essentially you will loose some top end speed since increasing torque will decrease speed. But for better acceleration i say a higher gear ratio will be fine, but you have to keep in mind that too much torque will just burn rubber and the car will not go anywhere until the tires slow down... it is true that a 3.73:1 will give you better gas millage but only in overdrive like in 5th gear... because you reach like a .75:1 gear ratio in fifth gear with 3.73:1 and if you bump up to 4.30 you get like a .90:1 gear ratio which is really close to fourth gear 1:1, so fifth gear will be something like 4 1/2
Threads Similar to: Gear ratios?
3.73 4.10 gear ratios SilverGT04 99-04 2 November 30th, 2010 06:39 PM
? (T-Lock And Gear Ratios) uniqueblackstang12005 V6 Mustangs 15 June 16th, 2010 06:49 PM
gear ratios in an 07 stang innrkid 2005 - 2010 15 May 22nd, 2007 12:38 AM
Gear Ratios dStoltenberg 5.0 Mustangs 15 April 19th, 2007 08:36 PM
Gear Ratios 00RoushV6 V6 Mustangs 16 February 20th, 2007 09:32 PM
