#21 |
¡ʇsnq ɹo uʍop ǝpısdn
thats a close one... same block same tune same PSI... i would bet on the M112... just cause the heads are more flowing ... and it has better revving capacity
#22 |
[8MINUS2]
I still think I'de vote on the MP-M90 over a stock m112....
Remember they both have to be tuned
#23 |
but your MPx is a tweaked rebuilt charger... stock for stock... including the charger unit itself i believe that the 112 could flow more cfms through the split port then the 90 through a single port...
i agree the MPx could out flow the 112 ... but if you send the 112 to MP they can work it to and your back to where i started ![]() and yes they will work the 112... but it doesn't have all the extra possibilities as the MP90 because they don't specialize in the cobra one... the lightning one though does have some options to it...
#24 |
1994 mustang v6
n/a
i read that u can use the mustang ecu on this setup, the m90 setup on the mustang car. is this ture? cause , how would it work?
#25 | |
[8MINUS2]
#26 | |
but then the MP112 is better then the MP90... MP90 can flow more then the M112
#27 |
the reason they say the SC ecu is cause its already set up for the supercharger... get a tuner and you don't have to worry about that
#28 |
1994 mustang v6
n/a
do u no how long will it take , if not runnin a tune on it, to f up the motor? cause i might just have to drive it to the tunner place
#29 |
it wont run ... and if it does it will be sooo lean that you might make it a day or two... your best bet is to contact justin starkey ... or dirty dirty racing... depending on what tuner you want
#30 | |
[8MINUS2]
Justin can write you a tune to get to the tuner if you stay under 2-3k!
#31 |
but if he keeps it with the stock injectors and no tune the computer wont be able to adjust will it? well not fast enough anyways ... it will just keep turning over ... i might be wrong i have never charged a car before
#32 | |
[8MINUS2]
After I remembered to connect the coil pack ground
Threads Similar to: M90 Supercharger
| SUPERCHARGER | emgjsdk1 | V6 Mustangs | 22 | September 30th, 2007 11:01 PM |
| best supercharger out there | 00GT | General Tech | 16 | April 11th, 2007 09:28 PM |
| supercharger | Mustang RacR94 | V6 Mustangs | 8 | April 7th, 2007 11:23 PM |
| Supercharger HELP!!!!! | pinkfloydfan311 | V6 Mustangs | 14 | December 1st, 2006 07:29 PM |
| Almost About To Get A Supercharger | FireryDriver | 2005 - 2010 | 8 | October 7th, 2006 02:14 AM |
