Discussing Dropping Below 500 Rpm And Starts A Shake in the V6 Mustangs Forum. Welcome to the forums Darrin. A tune isn't needed for a CAI for his ...
Old November 20th, 2007, 10:48 AM   #21
I Touch Myself Sometimes
HMUSN's Avatar
1991 GT
19.83 @ 12mph
A tune isn't needed for a CAI for his car.
In an 05+ I would agree with you completely though.
MILITARY CREW
FOUNDER
Originally Posted by itschristorres8 View Post
only bang for the buck is Foxs
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebands
email joe@tricktuners.com
Old November 20th, 2007, 11:07 AM   #22
98 Mustang GT
12.85
Normally I would agree, but I have seen this a lot depending on the car and the product that was installed.
If this is the only change that was made to the car and this happened immediately then I would check the installation to start with. Look for air leaks after the maf that are allowing in unmetered air. If the installation is good then it might be a good idea to reinstall the stock pieces and test it out that way. If the problem goes away with just that change then having the vehicle datalogged to monitor what is going on with both the stock air pieces and the CAI in place would likely show you what is up.
This is just one of those things that is just hard to say until you have all the data.
Hope it's an easy fix.
Darin
Old November 20th, 2007, 11:09 AM   #23
HMUSN's Avatar
1991 GT
19.83 @ 12mph
^ your intake has a leak somewhere past the MAF.
that would be my guess.
great minds think alike.
MILITARY CREW
FOUNDER
Old November 20th, 2007, 11:14 AM   #24
707Stang's Avatar
1969 Coupe
120.235@ however fast i ran that day
Originally Posted by ROUSHME661 View Post
mine does the same thing but mines drops so low it turns off ..i replaced the iac and tps but sitll no difference
I had that happen to one of my vehicles and it turned out that you cant just replace a tps they actually have to be calibrated. I found that one out after i fried my old one! just my two cents.
.....that's enough to make you want to rape kittens
Originally Posted by graystang01 View Post
he's a mexican. dont doubt his abilities
Classics or GTFO! Crew Member 3 of 4
For sale:
http://www.moddedmustangs.com/forums...ml#post1258167
Old November 20th, 2007, 12:05 PM   #25
98 Mustang GT
12.85
If you replace the TPS what you need to do is adjust the TPS voltage. I found a nice little write up on this at the link below.
Blue Oval Chips Inc. - Throttle Pos
Worst case scenario if you have to drill out the screw holes is that you can have htis done properly in less than 1/2 an hour.
Darrin
Old November 20th, 2007, 04:19 PM   #26
scubasteve041186's Avatar
2004 mustang 40th annv.
Roushme661
i'm with the other guys on the MAF could be dirty or there's a leak somewhere. if you get a chance take it all off and redo it all just to make sure everything is ok to begin with.
Old November 20th, 2007, 05:08 PM   #27
dgt_mustang's Avatar
01 mustang
im willing to bed that its my pcv valve, or the fuel filter, fuel filter hasnt been changed in quite a while, pcv valve neither, matter of fact, im on my way to autozone right now.
thanx guys, first thing im gonna try.
LEAVE REP POINTS WHERE NEEDED!!!
2001 mustang V6
CAI,
To come:
UDP, T-lok, 3.73, full exhaust setup W/flowmaster 40s, cobra Rs, aluminum driveshaft.
Old November 20th, 2007, 06:01 PM   #28
01 mustang
k, just bought the fuel filter, pcv valve, and some NGK v power spark plugs so im gonna install all tomorrow before i go on roadtrip for thanksgiving. anything special i need to know about changing fuel filter on the stang? pcv valve should be a straight unplug and plug. plugs are gonna be a bitch to change.
2001 mustang V6
CAI,
To come:
Old November 20th, 2007, 06:22 PM   #29
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
yea its a bitch ... you might need a tool to do it ... i can't remember... also use our fourm search tool to find installation guides and tips and tricks
slow car club - crew member 8 of 9
Originally Posted by omz
Old November 20th, 2007, 07:21 PM   #30
94v6blkndred's Avatar
1994 Mustang v6
slower than your average snail
yea watch your face cause its gonna get gassed on hahahah least thats what happened when we swapped my fuel filter
Old November 20th, 2007, 07:30 PM   #31
JASonic's Avatar
2004 V-6 232
Same here but Jugs told me to wear goggles and I actually listened. I had a similar problem after I had my intake installed. It was a leak and HMUSN identified it. Check every square inch of that sucker.
I will say this though. I had the same exact simptoms show up again later. It ended up being my alternator was going bad and was causing it to idle and act funky. Its just strange because the simptom was identical. New alternator and the problem immeadiatly disappeared.
http://www.youtube.com/watch?v=yeQLUyYg3EA
http://www.youtube.com/watch?v=ah1EbIOdAZE
K&N FIPK
Dual Flowmasters
Xcal III
Old November 20th, 2007, 07:31 PM   #32
HMUSN's Avatar
1991 GT
19.83 @ 12mph
MILITARY CREW
FOUNDER
Old November 20th, 2007, 09:42 PM   #33
ROUSHME661's Avatar
it might be unmetered air theres a hole for an air tmep sensor which mine doesnt have and i cant find anything to plug it in with it might be that so yeah and the tps was calibrated by my mechanic so i know it wasnt that..
01 v6
true duals with 40 series flows and custom h pipe
cold air intake
http://www.myspace.com/xxarsonfreakxx (PERSONAL)
Old November 20th, 2007, 09:45 PM   #34
C MY 4D's Avatar
2003 Cobra
11.98@119
V6 cars have hydroboost or vacuum assist brakes?
Black Cobra Club Member
Originally Posted by 8t6gt
Im more queer than a football bat I know this dude
Oh and BTW my emotional problems dont leave this IM :-D
Old November 20th, 2007, 10:48 PM   #35
2000 Mustang V6 n proud
13.1@107mph 2.1-60'
if your MAF is working i dont care what year car it is you shouldnt need a tune
your MAF is reading air still and sending to the computer to let the fuel injectors know how much fuel to shoot out with the amount of air going in
try cleaning or IAC and MAF as suggested. you can also unscrew your O2 sensors. if they're horribly black your rich, if they're white your BADLY lean.
try some fuel injector cleaner as well. and if you know how check your fuel pressure.
most likely you can just have a vacuum leak or IAC is dirty
mods:
more then you
where
TMA turbo, RPM-mustangs and www.crtperformance.webs.com
Old November 20th, 2007, 10:49 PM   #36
13.1@107mph 2.1-60'
a brake booster yes
mods:
more then you
where
Old November 20th, 2007, 10:58 PM   #37
C MY 4D's Avatar
2003 Cobra
11.98@119
a brake booster yes
My guess is either leaking brake booster, leak after the MAF, dirty IAC or bad TPS sensor.
Old November 20th, 2007, 11:05 PM   #38
JASonic's Avatar
2004 V-6 232
Is there a special cleaner at AZ or somewhere that is specificlly made for MAF cleaning? Or is there a multipurpose type product that is better?
K&N FIPK
Dual Flowmasters
Xcal III
Old November 20th, 2007, 11:06 PM   #39
C MY 4D's Avatar
2003 Cobra
11.98@119
more than likely its not the MAF but you can use electrical cleaner on it.
Old November 20th, 2007, 11:33 PM   #40
ROUSHME661's Avatar
just electrical cleaner ...imma clean the maf hopefully that helps ..and i use fuel injector cleaner every 5 or 6 full tanks and some octane boost every once in a while
01 v6
cold air intake
Threads Similar to: Dropping Below 500 Rpm And Starts A Shake
hard starts steve505gt 99-04 13 October 23rd, 2007 07:56 PM
OSU starts it off right! 03 R Code The Clubhouse 23 September 2nd, 2007 09:38 PM
Starts and Dies RDR61 5.0 Mustangs 4 July 4th, 2007 10:11 PM
Ping I cant shake Juggalo_X The Clubhouse 30 June 22nd, 2007 08:59 PM
starts then shuts off sean97gt Engine 2 January 18th, 2007 12:45 PM
