Discussing Dropping Below 500 Rpm And Starts A Shake in the V6 Mustangs Forum. Originally Posted by ROUSHME661 just electrical cleaner ...imma clean the maf hopefully that helps ..and ...
Old November 20th, 2007, 11:34 PM   #41
C MY 4D's Avatar
2003 Cobra
11.98@119
Originally Posted by ROUSHME661 View Post
just electrical cleaner ...imma clean the maf hopefully that helps ..and i use fuel injector cleaner every 5 or 6 full tanks and some octane boost every once in a while
thats not gonna clean the IAC or TB
Black Cobra Club Member
Originally Posted by 8t6gt
Im more queer than a football bat I know this dude
Oh and BTW my emotional problems dont leave this IM :-D
Old November 21st, 2007, 12:20 AM   #42
ROUSHME661's Avatar
i mentioned like 3 times that the iac is new i just replaced it ...
01 v6
true duals with 40 series flows and custom h pipe
cold air intake
http://www.myspace.com/xxarsonfreakxx (PERSONAL)
Old November 21st, 2007, 12:24 AM   #43
Hourofpain's Avatar
2003 Mustang V6
hint on the fuewl filter
turn it off via the switch in the trunk and then run your car and itl die mostly relieving all the pressure
Old November 21st, 2007, 12:55 AM   #44
scubasteve041186's Avatar
2004 mustang 40th annv.
o shit you sly bugger i never thought of that
Old November 21st, 2007, 06:58 AM   #45
dgt_mustang's Avatar
01 mustang
talkin about that inertia switch? i wasnt sure if that would be a good thing, but i geuss its the smarter of them all.
LEAVE REP POINTS WHERE NEEDED!!!
My Cars:
2001 mustang v6:
(slow for now)
1995 Mitsubishi eclipse GSX Turbo: <-ur expression
(Fast a hell)
Old November 21st, 2007, 12:49 PM   #46
its the gas cut off in the trunk i think on the left hand side looking into the trunk, behind the first panel, can't miss it. big red button
Old November 21st, 2007, 01:56 PM   #47
you need to turn the adjusting screw in on the throtle body linkage to raise your idle rpm... it shakes and rattles because the engine is not soppose to operate at that speed... if turning the adjusting screw to open the throtle does not work then u can look and hear for any vacuum leaks... on mine the pcv hose was disconnected and my car would not idle... for vacuum leaks I mean air that is entering past the mass aif flow sensor like in the intake tube or manifold...
Old November 21st, 2007, 07:41 PM   #48
El_Cangri's Avatar
2000 Mustang V6
i'm not gonna read all pages ...
for the problem check the IAC, fuel filter, MAF maybe the fuel pump isnt even workin well (but i doubt it) best bet woul be IAC or maf.. if u havent change the fuel filter maybe its that you could change it your self all you need is to buy a $1-3 dollar tool to disconnect it but first u need to turn off the fuel pump with the switch on the trunk or just the pull out the fuel pump fuse and run in until it dies
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old November 22nd, 2007, 12:25 AM   #49
2000Silverbullet's Avatar
2000 Mustang 4.2L
i have the same thing if you pump the brakes my car studders but doesnt stall. im gonna try a tune because i have a CAI but it only started till after I rebuilt the motor with new crank, cams, lifters, and pushrods my check engine light is on though and i suspect that is the prob. is your check engine light on?
http://i13.tinypic.com/2j0ku1y.jpg
2000 4.2 swap
Cold AIr
Mac Dual Exhaust
Old November 22nd, 2007, 07:46 AM   #50
01 mustang
yeah my check is light was on, for a vacumn leak or o2 sensors, those are getting cut off anyway though, now im leaving for gastonia, things replaced on the car, hope it does the trick, happy thanksgiving guys!
My Cars:
2001 mustang v6:
(slow for now)
(Fast a hell)
Old November 22nd, 2007, 10:36 AM   #51
ROUSHME661's Avatar
my check engine light isnt on...im still suspecting its the hole for the intake air temp on my intake so imma find something to plug it in with today hopefully that does the trcik
01 v6
cold air intake
Old November 22nd, 2007, 11:13 AM   #52
JASonic's Avatar
I had a hard time getting my inertia switch to trigger. I finally hit it with the handle of my screwdriver and it fooled the switch into thinking I was in a wreck.
http://rds.yahoo.com/SIG=1255914bh/E.../hondadyno.wmv
Hey, look at that... I have an AIM dude now.
http://www.youtube.com/watch?v=qurps9voLik
Old November 23rd, 2007, 02:18 PM   #53
2000 Mustang 4.2L
haha nice! idunno i spun out some time ago and maybe that triggered my whole thing, its more annoying than anything
2000 4.2 swap
Cold AIr
Mac Dual Exhaust
Old November 24th, 2007, 09:23 PM   #54
01 mustang
okay, funny thing here is, when i went to replace the pcv valve, there wasnt one in there at all, just a hose hooking up the two, i didnt get to replacing the fuel filter because i couldnt get the filter off of the metal line, not the one coming from the tank but the one that connects it to the rest of the car, it came off easy from the other side, is that what your saying is that i need the disconnect tool for that?
My Cars:
2001 mustang v6:
(slow for now)
(Fast a hell)
Old November 24th, 2007, 09:28 PM   #55
I Touch Myself Sometimes
HMUSN's Avatar
1991 GT
19.83 @ 12mph
^ yup.
you need a special tool for it.
MILITARY CREW
FOUNDER
Originally Posted by itschristorres8 View Post
only bang for the buck is Foxs
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebands
email joe@tricktuners.com
Old November 25th, 2007, 06:29 AM   #56
mhmm what he said. didn't it come in the box?
Old November 25th, 2007, 12:23 PM   #57
01 mustang
tool didnt come in the box, just the little hairpins which ill probably use my old ones anyway cause old ones are metal, new ones are plastic, buying the disconnect tool form work today though when i clock out.
My Cars:
2001 mustang v6:
(slow for now)
(Fast a hell)
Threads Similar to: Dropping Below 500 Rpm And Starts A Shake
hard starts steve505gt 99-04 13 October 23rd, 2007 07:56 PM
OSU starts it off right! 03 R Code The Clubhouse 23 September 2nd, 2007 09:38 PM
Starts and Dies RDR61 5.0 Mustangs 4 July 4th, 2007 10:11 PM
Ping I cant shake Juggalo_X The Clubhouse 30 June 22nd, 2007 08:59 PM
starts then shuts off sean97gt Engine 2 January 18th, 2007 12:45 PM
