#1 | |
Glorious PC gaming master race
Projector Headlights
i just put led projector headlights on my car and one of them is really off. it lights up the inside of trucks as they drive by me. how do u adjust the angle on these things?
![]() MILITARY CREW - USAF E-4
#3 | |
thats for the stock headlights... i got the projectors from americanmuscle.com. i couldnt figure out how to adjust them tho
then I have no idea man. Sorry
#5 | |
its ok. has any1 done this to their car?
I have them... I have the same problem, only to low... But I don't know how to adjust them...
2002 GT
¡ʇsnq ɹo uʍop ǝpısdn
wait they don't adjust the same way that normal lights do?? see if you can pop that sucker out and tinker with it a bit... btw you won't be able to send it back either most big companies run a no return policy once the box is opened
2005 Torrid Red GTO m6
this is gonna get moved buddy.
This type of stiff belongs in the visual section
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. |
#9 | |
i took them off yesterday and noticed there was a knob on the back. i tried turning it but it wouldnt move. im just hoping no one will wreck when they pass me. i really need to get this fixed and id rather not take it to a garage and hafta pay em 2 do something i can do at home
yea I have the same problem but mine shine in the ground too
Fog Lights eventually! |
MM's Database Error
email the company and ask..
#12 | |
i cant believe that no one can tell me how 2 fix em. OMZ or itschristorres will probly find this and explain it perfectly by the end of the day lol
#13 | |
ive emailed em 4 times in the past 3 days and i cant get a reply
I don't know man i have never had projectors to European for me... you tried turning the knob? did it look threaded and meant for turning? also does everything else line up correctly?
#15 | |
yea i guess its meant 4 turning... its sticking out farther than the one on the other light. its kinda annoying and i really need 2 fix it. im afraid im just gonna hafta take it 2 a garage and pay them 2 fix it
since u guys are all suffereing i decided to go into my garage and look in all those boxes to find my projectors to help u guys out here ya go..this is for 99-04 i dont know how the other models work bu hope this helps
![]() basic picture of a projecotr headlamp ![]() there is a screw behind the headlamp on the inner corner ![]() u can either stick a phillips head screw driver and turn just like the oem headlights ![]() or u can turn it from the back with a socket .. park like 5-8 feet from a wall or garage door and aim ur beams to it adjust both headlamps as needed projectors have really sucky beams thats why i swithced back to oem but have fun and enjoy hope it helped
01 v6 true duals with 40 series flows and custom h pipe cold air intake http://www.myspace.com/xxarsonfreakxx (PERSONAL) http://www.myspace.com/vicious_racing (THE STANG FAMILY)
my projectors are non-adjustable. They're terribly aimed and that's just how they are. You can only adjust the position of the entire headlight assembly by adjusting the three black clips that hold it in place, but that doesn't help much because the low beam is pointed way too low and high beam is pointed way too high. you can't adjust them independantly.
ROUSHME's lights are the first projectors i've ever seen that actually seem to be fully adjustable...depends on which ones you have I guess. |
all the projectors i have seen are like mine they all have an adjustment screw
see thats what i thought i was pretty damn sure there was a nut on the back that you could twist
yea like i said all the ones ive seen are like that .. if u guys need any more pics let me know before i put it back into the garage lol
Threads Similar to: Projector Headlights
| Projector Headlights came loose | Murderjetz | General Tech | 0 | September 28th, 2007 10:38 PM |
| projector headlights install | xiiiix | Visual | 6 | April 9th, 2007 11:06 PM |
| Projector Headlights Conversion To HID... | 97TunedMustang | Visual | 1 | September 21st, 2006 04:04 PM |
| black JDM projector headlights | bbrewer03 | 96-98 | 0 | August 26th, 2006 03:09 PM |
