v6 mod list take a very extensive
Old August 28th, 2006, 02:43 AM   #1
98lean is on a distinguished road
i got this from pinto beast who is on 3.8mustang.com he is a member and this is his write i thought you guys might appreciate this. i didnt write this
Most people buy the v6 for the lower amount of money that it takes to get into the car, be it insurance or just cheaper price. Most people are left wanting more out of their car and I hear all the time on here that it takes a small fortune to make a V6 go fast. That is not true. It seems to me that the people that are complaining about it the most are the people with the most appearance mods.
I think if you are working on modding a car and working on a tight budget you must make a choice. You can go for appearance and the car will look great but still feel like your driving a Taurus or you can leave the appearance as is (which I don’t think they look bad at all) and focus on performance. With a small investment, less than the cost of putting a super charger on and hopefully get to the high 13’s or low 14’s I’ll tell you how to mod the car to run 12’s for around $3,000. Learn to do the work yourself. If you can’t and your not rich then modding a car might not be for you. Read books, jump in and do it and learn as you go, nothing is that hard that it can’t be learned through doing it. There are plenty of places to ask questions and get answers.
First off, go with the biggest bang for the buck mods, and a cold air intake is not one of them. All of the mods that I’m going to suggest is big bang for the buck mods.
First- UD pullies- They are not a must but they do help. For the $80-90 you will spend on them new they are worth a couple of horse power. They are not a big gain item. Look for used gears, used just means cheaper.
Your cost is at $85
Exhuast- Not a real big gainer either unless you have bigger mods to support it. You don’t have to spend an arm and a leg on exhaust. You can go to a muffler shop and have them build you a dual set up cheaper than what any cat-back or after market company can offer after shipping. I paid $250 for my duals with flowmasters. I wouldn’t pay much over that for an exhaust system.
Cost is at $335
T-loc- If you are pushing any power you want to be able to get traction. I’m using a used T-loc that has been rebuilt. I’ve had it in my car now for 5 years under some pretty good abuse and never had a problem. I paid $100 for mine, look for a deal on one I wouldn’t pay any more than $250 for one on a budget.
Gears- Make a choice 3.73’s or 4.10’s. See which ones will be right for you. Gears are something that personally I would not get used. I bought Richmonds new and never had a problem with them for $165. I would not suggest installing your own gears and T-loc unless you really know what you doing so I factored in an average $300 installation fee.
Cost is at $1050 ($165 for gears), ($250 for T-loc), ($300 for installation)
K&N filter- I personally think that a K&N filter in the stock air intake tube is just as good as a CAI. That is just my opinion so I would spend the $25 for the filter and leave it at that.
Cost is at $1075
Cam- You will really notice a big difference in the car with a cam. I am using a 207 cam from RPM and really like it. All in all they are a little tricky to install but nothing that anyone who was taking their time and had a good over view of the procedure with a manual couldn’t do. I paid around $180 for my cam.
Heads- These will make the biggest difference in performance. They are pricy though too. Super Six sells a pretty good set for around $1000. I got mine from Gaston who P&P’s them (from V6power.com) for $500. I really like them and he did a fantastic job. While the heads are off this is the best time to do the cam, no worries about holding the valves up and just makes things simpler to do. I also think putting valve spring on heads is a lot easier when they are not on the car.
Valve springs- You will need to get a set of valve springs to go along with the cam and perhaps some push rods. I suggest the adjustable roller rockers and then you can keep you stock push rods. Expect to pay around $100 for a set of springs.
Gaskets- they are more expensive than you think. For upper and lower intake, head, water pump and front seal along with head bolts it cost me around $250. I got all Fel-pro stuff.
Cost is at $2355 ($750 for heads), ($180 for cam), ($100 for valve springs), ($250 for gaskets)
Roller rockers- They make a big difference over stock rockers and you can tell why when you look at them side by side. I suggest the adjustable rockers.They are aroung $255 for non adjustable and $360 for adjustable.
Cost is at $2715
Nitrous- nitrous is the biggest bang for the buck mod there is. With no other mod can you spend $500 and get 100 hp out of it. I like the Zex kits but NX is also a very good brand. You can save a lot of money getting a used kit. Ebay is always full of them and they come up for sale on the boards from time to time. I paid right around $500 for mine and around another $150 for accessories.
Cost is at $3365
Tuner or chip- I like the SCT X-cal. For $420 you can’t get a better deal. Chips can tune as well but you are stuck with what is on the chips and if you change your tune needs they have to be sent off and reprogrammed. The chips run around $350.
Cost is at $3785 ($420 for tuner)
Other misc stuff your going to need along the way like a Maf can be found for cheap as well used. I found my maf for free from a friend. Keep your eyes open for any thing you think you might need. If you can get a part for free and you might not use it you can always sell or trade it for something that you do need.
Auto's may need additional help as well. The addition of a higher stall torque converter would help tons with the aod
Last year GT’s went for around $23800
V6 mustang sold for around $18900
Difference of $4900
The build I described and priced out will have you putting car lengths on GT with ease for around a $1000 less than they paid for their car as is.
1998 V6- A few mods, kinda quick 12.9@106
Old August 28th, 2006, 03:13 AM   #2
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
hmm, i was thinking bout gettin heads, but i have no where to start from nor whihc i should get...plus after reading this its seems like u dont only have to get heads, but other stuff, the cams i agree is a good idea. i should look into that, the UD pulley and t-loc....question tho
if i get t-loc do i need positive traction then?
also the 3.75 gears...wat does that do for your car? alot of ppl suggest them
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 28th, 2006, 10:30 AM   #3
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
3.73 gears allow your driveshaft to turn more revolutions in relation to how many times you rear axle turns, therefore allowing you to get up to speed faster by lowering the ratio.
T-loc is the mustang equivalent of Posi trac.
Old August 28th, 2006, 03:32 PM   #4
00 V6 & 09 GT
ohh lol i look dumb...lol thnks though
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 28th, 2006, 07:55 PM   #5
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
don't sweat it we all start somewhere
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old August 30th, 2006, 07:45 AM   #6
Steven89593's Avatar
02 Mustang GT
Steven89593 is on a distinguished road
any idea of what the HP gain is with those mods?
Old August 30th, 2006, 03:21 PM   #7
00 V6 & 09 GT
these are estimate based off what ive seen on sites:
UD pullies- 10- 15+hp
exuast- this wont give u much hp until uve got a modded engine, but ive heard 25 hp
t-loc- none, just better traction
K&N filter- well the actually cold air intake 5-15hp maybe more, i doubt it
cams- 20- 25 hp if not more
heads- no clue =/ srry
valve springs- supports your extra hp
Gaskets- idk srry
nos- well ive heard that a 100 shot, everytime u shoot gives u 60hp
tuner chip- 15-25 hp maybe more depending on ur chip.
these are all not 100% correct more lik an educated guess, if anyone see one of mine are wrong feel free to correct me. as long as u dont call me an idiot or etc...
as for the cam gears..where can you get that?
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 30th, 2006, 03:55 PM   #8
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
its posts like these that make me really want to fix up the ole 6er... and to think i was thinking about juss putting a v8 in the car... hahaha. ill stick with the 6
3.8Coastie
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old August 30th, 2006, 08:48 PM   #9
Sa-WaitNoMustang900Turbo is on a distinguished road
UDP: 8hp(this is usually the average on all dyno tests for almos all cars i have seen)
CAI:-7hp to 7hp(yes you will lose power if you do not take in cold air from outside engine bay, what i would do rather than a CAI is the windstar manifold mod with some sort of custom way to get cold air, 10hp)
cams: ill guess around 20-30 for some good ones and probably more for a pre 99 model(still wont be as fast with the same mods i beleive though, but cams can make a bigger difference than you might think, 20-30hp is alot for a 200 hp car)
chip: only allows you to take full advantage of the present set up if done right, so there is no one hp#
port and polishing heads: I know for the saab 900 (2L 4 cyl turbo charged) this will give you about 15 hp, but how much power it will give you is entirely dependent on how much better you will be able to increase flow(if your engine is restrictive this will give you more, if it is free flowing it wont give you as much, this mod, what ever the engine will make it feel and rev alot better in the high rpms, and if you have a very high rev limit or increase it, then this mod will help you even more, this mod also makes your torque and hp drop offs be at a higher rpms, maybe out of your rev limit, in addition to usually making the power curves more linear
God... That Euro import guy is really starting to get on my nerves... my car can only beat his in a strait line(maybe)
Old August 31st, 2006, 01:23 AM   #10
00 V6 & 09 GT
how often does that happen?
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 31st, 2006, 10:06 AM   #11
AtlanticBlue99's Avatar
14.79 @ 92.15
very often. people without a heat shield will bring in hotter, less dense air with less oxygen and lose power.
ModdedAutos
1999 Mustang V6
Old August 31st, 2006, 01:30 PM   #12
00 V6 & 09 GT
a heat shield...thats basically that plate covering the whole where ur intake is right? i have one of those though...so does that mean it wont happen to me as much or at all?
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: v6 mod list take a very extensive
can we get a list Dennis The Clubhouse 19 November 11th, 2007 03:10 PM
list stupidstang V6 Mustangs 45 August 17th, 2007 06:34 PM
My wish list MustangMatt96GT 96-98 17 April 2nd, 2007 08:31 PM
Mod list leebunnyz 2005 - 2010 8 March 20th, 2007 08:09 PM
