Help! I Need Help Someone Please (Battery)
Old December 4th, 2007, 09:44 PM   #1
2000 mustang v6
kampa is on a distinguished road
ok am new to the stang world and i just recently started having problems cracking the car , the battery drains after turn off and when i try to start it i hear a cracking noise and then the engine starts goin on slowly and just today my headlamps dont turn on at all does anyone knows whats goin on with my car ???
Old December 4th, 2007, 09:45 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
replace your battery.
and in the mean time run a load test on your alternator
Old December 4th, 2007, 09:46 PM   #3
1990 hatchback lx
Twist it up is on a distinguished road
Send a message via Yahoo to Twist it up
probably a loose cable arcing is the cracklin noise you hear.
www.hsvracing.com
Old December 4th, 2007, 10:55 PM   #4
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
i was thinking it sounded more like a lose wire or bad ground
Old December 4th, 2007, 11:29 PM   #5
Fox2102's Avatar
'03 Harley Sportster 1200
Fox2102 will become famous soon enough
Send a message via AIM to Fox2102 Send a message via MSN to Fox2102
Yeah try tightening your battery cables and making sure they arent rotted or split anywhere. If that's not it then have the battery and alternator tested like they said
Old December 5th, 2007, 01:22 AM   #6
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
+1 on all above
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old December 5th, 2007, 03:30 PM   #7
Replica R's Avatar
Replica R is on a distinguished road
oh man I was changing my powersteering pump on my 'stang, why is it that I hear so many v6's with bad powersteering, anyways when I was taking my alternator off I accidently broke that little screw in the back that holds the grounding wire on. Yeah didn't make it very far after that, had to get the whole thing replaced!
Friends Don't Let Friends Drive Rice!
Old December 5th, 2007, 11:55 PM   #8
2000 mustang v6
well i got my headlights to work seems like the 9007 xeon lights kinda burn the plastic and i changed them to the stock light bulbs and they work now , i also check and i open the switch and i saw that the needle of the battery meter is normal , but once i try to crank it on the voltage goes low and as its trying to turn on the deedle rises up , who knows whats goin on with this car , thou it might be the battery but the battery has like a little peep hole that says when its bad or good and green is good and red is bad , but it reads green ,
Old December 6th, 2007, 01:19 AM   #9
drumming_guitarist06's Avatar
2000 Ford Mustang
drumming_guitarist06 is on a distinguished road
Send a message via AIM to drumming_guitarist06 Send a message via MSN to drumming_guitarist06 Send a message via Yahoo to drumming_guitarist06
I'd check out your alternator if I were you. Don't trust the peep, take it somewhere that really tests them.
Old December 6th, 2007, 02:59 AM   #10
Onemanzu's Avatar
do you have one of the batteries where you need to add water? look in it and see if it needs some more water... i had that happen to my old rx7
Old December 6th, 2007, 05:09 PM   #11
2000 mustang v6
is it just regular tap water ??? ill give it a try today and see what happens thanks for the tip
Old December 7th, 2007, 01:37 AM   #12
Onemanzu's Avatar
it will say on the battery if it needs tap or bottled (purified)
Old December 7th, 2007, 02:24 AM   #13
MWWarlord's Avatar
Hey Kampa did adding water help? If so Onemanzu LOVES REP.
MWWarlord
Old December 7th, 2007, 02:33 AM   #14
Onemanzu's Avatar
i think he already repped me
Old December 7th, 2007, 11:13 PM   #15
2000 mustang v6
ok i opened the battery caps and seems like the acid/water is ok , i give up on this , ill just get a new battery and see if it works like that , hey guys u think its the is the battery saver fuse ????
Old December 7th, 2007, 11:19 PM   #16
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
test the alt and change the battery
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old December 8th, 2007, 01:44 PM   #17
Moderator
Batteries do not last forever. Just because the electrolyte level or quality is fine doesn't mean the battery is good. The plates inside the battery could be bad.
Now, if your battery is relatively new, then I could say maybe you have a constant draw problem somewhere in the car. If your battery is 4 or 5 years old, then I would say it's time to replace the battery, and load test your alternator, as stated above.
Old December 8th, 2007, 01:44 PM   #18
HMUSN's Avatar
iTrader: 9 reviews
^ what this guy said
Old December 8th, 2007, 01:46 PM   #19
Moderator
Nooo, listen to this guy!
Old December 8th, 2007, 03:22 PM   #20
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
OK i WOULDNT blame your altnator yet or battery
if its draining its because you have short somewhere
an eletrical problem
more then likely the alternator will not drain a battery over night if the cars isnt on...
if it was a bad alternator the car would turn on(assuming the battery is good) then slowly die and have the car running off the battery then you'd kill the battery and just shut down. a jumpstart and the same thing happens thats your alternator
if you get a jump start and the car runs fine but you keep needing a jump start..battery.
I can start my car and disconnect my battery and you'll see it on
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: Help! I Need Help Someone Please (Battery)
Battery Hourofpain The Clubhouse 4 November 8th, 2007 06:33 PM
Battery ebo 4356 96-98 9 August 28th, 2007 09:15 AM
battery relocation with second battery onewinner 5.0 Mustangs 1 May 30th, 2007 12:30 PM
Battery Mustang Mike 99-04 2 February 27th, 2007 08:07 PM
I Have A New Battery 232stang V6 Mustangs 9 November 9th, 2006 07:20 PM
