Discussing Conventional vs. Synthetic Oil in the V6 Mustangs Forum. Perhaps I can offer some insight as a chemist. From what I can find on ...
Old February 8th, 2008, 11:04 AM   #21
From what I can find on the internet, conventional oil base stock is a complex mixture of organic molecules, including aliphatic and aromatic hydrocarbons. To this is added a lot of other things including detergents, viscosity additives etc.
Synthetic oil is also hydrocarbon based, it's just that it's a mixture of fewer specific molecules. It contains pretty much the same additives as conventional oil. It may be that by selecting exactly what goes in it that the properties can be somewhat optimized.
However, the two are very similar, a mixture of various hydrocarbons and additives.
Old February 8th, 2008, 11:06 AM   #22
shadow5403's Avatar
2000 V6 Mustang
Either way, you need to properly change your oil. Yeah synthetic will hold up longer...but you should still at least change the oil filter and check the level and add a quart if need be if yur gonna go over 5k without a change.
Threads Similar to: Conventional vs. Synthetic Oil
Synthetic Youngin V6 Mustangs 43 August 31st, 2007 11:02 AM
conventional to synthetic WilltheThrill 99-04 18 August 23rd, 2007 09:30 PM
synthetic oil ? Blackbeauty v601 V6 Mustangs 6 July 31st, 2007 10:05 AM
Synthetic vs. semi synthetic vs. standard stagecrewgod Engine 2 March 29th, 2007 09:33 AM
Synthetic Oil TedG954 2005+ 33 March 5th, 2007 11:23 AM
