Discussing Compression Ratio in the V6 Mustangs Forum. Ok so explain this to me. How do you change the compression ratio of your ...
Old December 5th, 2007, 11:33 PM   #1
scxc15's Avatar
2003 Mustang V6
15.96@87.08
Compression Ratio
Ok so explain this to me. How do you change the compression ratio of your car? Like can you use your stock internals and rebuild it to raise or lower the compression ratio.? And I saw on SSM if you buy the 4.3 stroker somehow your compression can be between 8.7-11.5:1.... Also is my understanding that higher compression ratio is better for engine only applications and nitrous. While lower compression is better for s/c and t/c, is that correct? Also does having a higher compression ratio mean more horsepower? Yea I know its alot of questions.
Old December 5th, 2007, 11:59 PM   #2
Avaric3's Avatar
1999 V6 Mustang
bolt-on auto shootin for a 14.4-14.6
Originally Posted by scxc15 View Post
Ok so explain this to me. 1 How do you change the compression ratio of your car? 2 Like can you use your stock internals and rebuild it to raise or lower the compression ratio.? 3 And I saw on SSM if you buy the 4.3 stroker somehow your compression can be between 8.7-11.5:1.... 4 Also is my understanding that higher compression ratio is better for engine only applications and nitrous. While lower compression is better for s/c and t/c, is that correct? 5 Also does having a higher compression ratio mean more horsepower? Yea I know its alot of questions.
ill try my best to answer your questions:
1-you can mill your heads or change pistons to change the ratio. im not sure if there are other ways tho
2-no
3-yes, ssms can alter the compression ratio by using different pistons. dish pistons give you a lower ratio, flat tops are the medium and domed pistons give the higher ratios
4-try to keep it below 9:1 for blower or turbo apps and about 10:1 or 10.5:1 for nitrous. for n/a you can go as high as 11.5:1 on pump gas but itll require premium
5-yes, it means more hp. how much tho, im not sure
Originally Posted by ford_racer View Post
go stop a Peterbilt with your face.
Originally Posted by Screamin Cobra View Post
You should stencil FAIL on it and send it back.
Originally Posted by HMUSN View Post
v6 mustang are ghey
Originally Posted by mjnd1990 View Post
But my body produces testosterone so I'm not sure about a V6
Old December 6th, 2007, 12:29 AM   #3
2000 Mustang V6
unknown @390
^ nailed it
let me just fine tweak it
1- you can also use a thicker head gasket. VW did that way back. theres no thicker head gasket for our car anyway.
2-you can use the stock crank thats about it.
3-correct
4-depends on what your goal is..if you dont plan on breaking over 500rwhp i'd do a 9:1 CR for more power vs 8:1....example..9.5:1 CR for 350-450rwhp area
nitrous 10:1 is good! n/a 11:1 no doubt!!!
5-8:2:1 ran like 226rwhp 284rwtq fully built and SSMS ran 10:5:1 at 260rwhp 260rwtq built as well
www.crtperformance.webs.com
Old December 6th, 2007, 02:42 AM   #4
SSStang's Avatar
2k2 Mustang V6
Originally Posted by itschristorres8 View Post
^ nailed it
3-correct
Actually chris, their are thicker head gaskets for our cars:
Tom Morana Racing Engines
Selling for friend: Vortech Supercharge kit < 100miles.
Old December 6th, 2007, 08:28 AM   #5
scxc15's Avatar
2003 Mustang V6
15.96@87.08
So if I wanted some of those to raise my compression I would get the 4-layer gaskets?
Old December 6th, 2007, 12:19 PM   #6
MM Phantom
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
to raise it you want the thinnest gasket you can get... and maybe even shave a bit of your heads
Back for brotherly love. My thoughts are with you Bubba!! [9-23-08]
Originally Posted by omz
Old December 7th, 2007, 01:24 PM   #7
scxc15's Avatar
2003 Mustang V6
15.96@87.08
Which one on that website is the thinnest?
Old December 7th, 2007, 01:40 PM   #8
MM's official Chevy guy
whitemustang02's Avatar
2002 Mustang V6
I believe the thinnest is the 3 layer one
Also what octane rating would I probably need if I went with a 12:1 or 12.5:1 set up
"Speak softly and carry a big stick" - Theodore Roosevelt
"Any idiot can make a V8 fast, it takes a real idiot to make a fast V6".
Originally Posted by Heather View Post
Me likey mikey
Old December 7th, 2007, 06:42 PM   #9
Avaric3's Avatar
1999 V6 Mustang
you can run 12:1 or 12.5:1 if you want but one bad octane tank of premium and your fucked and can say goodbye to your engine or whatevers left of the internals
personally i think and i think most others would agree that on pump gas, the highest you should go is 11.5:1 or 11.6:1
v6 mustang are ghey
Old December 7th, 2007, 08:02 PM   #10
2000 Mustang V6
unknown @390
i wouldnt go to far past 11.5:1 for 93octane and really 11.1:1 is still kinda high for a DD
a thicker head gasket will lower your compression a little
milling your heads is like shaving them. that ALSO can RAISE compression
but if you swap the cam for a bigger lift at all you stand a good chance of your valves hitting the piston with the stock piston. i dont know if just milling it will do it but
truly...its not worth it...the power difference wont be to noticable from just milling
you im not sure how much power but id say you'll be lucky to see 20bhp off just milling SAFELY
Threads Similar to: Compression Ratio
Compression Ratio itschristorres8 Engine 22 December 1st, 2007 01:46 PM
Compression Ratio scxc15 Modular Mustangs 4 September 24th, 2007 11:01 PM
Compression ratio w/supercharger TheBusher 99-04 19 September 16th, 2007 02:10 PM
compression ratio mustangrebuilder Classic Mustangs 13 August 14th, 2007 10:08 PM
96 gt compression ratio 96_gt_stanger 96-98 3 March 2nd, 2007 11:52 PM
