Found out what the whine was coming from the rear end...
Well my car ran fine all day until i went to the store. I came out and tried to start it and it wouldnt turn over. It was like it was out of gas. Then i noticed when i turned the key to the on position i didnt hear the fuel pump(assuming that's what the noise is) turn on. I had noticed a whine coming from my rear end but wasnt sure what it was but i'm pretty sure now it was the fuel pump....
What i need to know is if anyone can give me a price range on how much it's going to cost to replace cause i dont have the skill or tools to replace it myself... |
#2 | |
04 Mustang
![]() Sponsor: Chips V6 Specialties < 2004 238C.I. 3.9L V6 Mustang Dual Exhaust,Shaved GT Bumper,Tinted Lights,8000K HID Kit |
oh it's a 97... keep forgeting the new forum doesnt display the car in your garage...
04 Mustang
Ford Mustang 3.8 V6 1994-1997 OEM Replacement Fuel Pump
idk what installation would be but i found the pumps
Thanks. That helps a little but i really need to know about how much an install will cost. I was thinking about $350 or so for everything but i dont really know
You should probably check first before you go and start replacing parts without knowing for sure. Turn the key to on for a few seconds then back off. Then go crack the bolts on one of the fuel lines and see if you have any pressure and/or fuel coming out. If you get nothing after backin it out all all the way then itd be pretty safe to say your pump is shot.
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
¡ʇsnq ɹo uʍop ǝpısdn
good call TM ... check your fuel pressure... release it in a clean safe way... turn your car to the on position at (cause it runs the pump for a second or two) then see if you still have pressure
#8 | |
or you could stick a funnel down in your tank then have someone crank the car and listen for the pump. if you here a buzzing noise coming from the funnel then your pump is good. also there is a way to prime your fuel pump directly with a dmm and the battery but i dont remember because its too late. i need to study that. also i forgot de we have a schrader valve on our fuel rail. im pretty sure the old fox bodies do.
Threads Similar to: Found out what the whine was coming from the rear end...
| knn whine? | chadwick297 | 2005 - 2010 | 10 | October 23rd, 2007 01:45 PM |
| gear whine? | 94v6blkndred | V6 Mustangs | 5 | July 6th, 2007 11:44 AM |
| SPEAKER WHINE | 04gt | 99-04 | 6 | June 11th, 2007 05:27 PM |
| What is that Gawd awful rattling coming from my rear end?!?! | 06SCGT | 2005 - 2010 | 10 | January 9th, 2007 11:10 PM |
| Strange Noise Coming From My Rear | 92_fox | 5.0 Mustangs | 12 | November 14th, 2006 09:58 AM |
