Tire Size
Old December 14th, 2007, 02:51 PM   #1
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
Tire Size
will the rim tire size 225-R55-16 fit on my 01 ford mustang? i only ask cause i got a great deal on the rims and tires that i want.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old December 14th, 2007, 02:52 PM   #2
2001 Mustang 3.8l
my current tire size is p205/65R15
Old December 14th, 2007, 02:53 PM   #3
TurboLX's Avatar
1988 Mustang LX Turbo
it will fit fine
Old December 14th, 2007, 02:54 PM   #4
2001 Mustang 3.8l
like....100% fine? clearance between the fender and everything? what about when the wheel turns sharp? clears the inside?
Old December 14th, 2007, 02:56 PM   #5
TurboLX's Avatar
i was running 225/55/15's on my fox a few years back
im running 290's now, they'll fit just fine
Old December 14th, 2007, 02:59 PM   #6
2001 Mustang 3.8l
k, thanx
Old December 14th, 2007, 03:02 PM   #7
2001 Mustang 3.8l
sorry to bother again, does the size 245/50-16 fit?
Old December 14th, 2007, 03:04 PM   #8
TurboLX's Avatar
yep, they'll rub a little when you turn it sharp in the front tho
Old December 14th, 2007, 03:06 PM   #9
Blainestang's Avatar
Blainestang is on a distinguished road
205*.65 = 133.25 mm (profile)... 26.49" total height
225*.55 = 123.75 mm (profile)... 25.75" total height
25.75 / 26.49 = .972
Your new tires will actually be LOWER profile than the old ones, meaning a lower overall height. Because of this, your speedometer will actually read slightly higher than your actual speed.
So, if your speedo is reading 60mph:
60*.972 = 58.3 mph
So, that's the change there, and you'll certainly be good height-wise.
Width-wise, you SHOULD be fine, considering that stock '03-'04 Cobras came w/ 275-width tires all around.
One problem I could see, though, is if your new wheels have some strange offset. Are these factory Mustang wheels? If not, what are they, and what is the offset/backspacing?
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles
2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP)
2001 Harley Davidson F-150
Acts 16:31
Old December 14th, 2007, 03:11 PM   #10
Stock GT's came w/ 245/45/17's
245*.45 = 110.25 mm = 4.34 in * 2 +17" = 25.68"
245*.50 = 122.5 mm = 4.82 in *2 + 16" = 25.65"
Almost EXACTLY the same height-wise, and while there MAY be some rubbing at full lock, it shouldn't be a big problem, considering they came stock on GT's.
Acts 16:31
Old December 16th, 2007, 05:08 PM   #11
2001 Mustang 3.8l
would 17" rims with tire size 205/45/17 fit?
Can i put my existing tires i have on the car on the 17"s??
Threads Similar to: Tire Size
Tire Size 89StAngerLX 5.0 Mustangs 2 December 10th, 2007 11:27 AM
Tire Size Mstngdtb 5.0 Mustangs 3 September 7th, 2007 12:31 PM
Tire size???? noob 99-04 5 May 27th, 2007 06:44 PM
Tire size 89 LX...... hot89 5.0 Mustangs 14 May 23rd, 2007 09:45 PM
Tire Size notsoslo5.0 5.0 Mustangs 4 October 13th, 2006 05:35 PM
