2006 Std Brake Noise
Old September 3rd, 2006, 09:20 PM   #1
casey is on a distinguished road
Just bought my wife a 2006 (non-gt) auto trans.
It currently has 400 +/- miles on it and a metal on metal noise coming from passenger side front tire. Same noise as when your pads have run low, except it's always making the noise with varying degree's of volume and pitch.
When I hit the brakes sometimes the noise softens or goes away altogether then returns immeidiately or shortly thereafter.
We're going to bring it in to a dealership hopefully they're open tomorrow (Labor Day) otherwise Tuesday.
Any ideas?
Old September 3rd, 2006, 11:02 PM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
e-brake stuck? seized caliper?
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old September 3rd, 2006, 11:05 PM   #3
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Re: 2006 Std Brake Noise
Originally Posted by casey
Any ideas?
Who cares? It's under WARRANTY!
BTW Welcome to MM and glad to have ya!
Old September 3rd, 2006, 11:16 PM   #4
mdvaldosta's Avatar
11.47@120.58
The noise is coming from the front, so not the e-brake. Could be a stuck caliper, I'd say probably a bearing if it is in fact a metal noise. Either way...
Pretty much sums it up, heh.
Old September 4th, 2006, 03:16 AM   #5
didn't see the word "front" so md is right it isn't the e-brake
Old September 4th, 2006, 07:50 AM   #6
Thanks
Thanks for the replies ... I'll keep you posted.
Old September 4th, 2006, 03:41 PM   #7
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
Warranty=your best friend.
go to ford tell them ta fix it
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 4th, 2006, 05:28 PM   #8
marknlori's Avatar
marknlori is on a distinguished road
I had the same problem with my 04 F-150 and took it to the stealership to have a brake job done to it, they put it on the rack and told me that the brakes were fine and didn't need to be replaced. I disagreed when the service mgr. told me that the reason you are hearing the problem is that they stopped using the old kind of brakes made from asbestos and are now using the whole new kind of material for brakes. The brakes will crystalize and therfore that is were the noise is coming from. IMO, I would have a brake job done as I did with my F-150 and the noise stopped.
Hope this helps.
Old September 4th, 2006, 06:31 PM   #9
Thanks
We dropped it off earlier, service dept. was closed. Should have some answers tomorrow.
Casey
2006 Mustang V6
Charlotte, NC
Old September 4th, 2006, 06:34 PM   #10
mdvaldosta's Avatar
11.47@120.58
Keep us posted : )
Old September 5th, 2006, 05:23 PM   #11
Picked up the car earlier. They test drove and heard the problem. Removed the front tire, didn't find anything and put it back together. Test drove again and the problem was gone.
They're guessing a small rock was somewhere within the brake system and it must have fallen out when they removed the tire.
The sound IS gone but I'm not sure I trust the diagnosis, time will tell.
Casey
2006 Mustang V6
Charlotte, NC
Threads Similar to: 2006 Std Brake Noise
TSB 07-20-3 Cable Tension Noise - Built before 12/01/2006 ujslost General Tech 1 January 18th, 2008 12:31 AM
Brake noise... I got vid to show you MustanG_guy17 V6 Mustangs 23 August 13th, 2007 07:30 PM
Brake noise..Need HELP!!! MustanG_guy17 The Clubhouse 1 August 9th, 2007 12:02 AM
Weird E-Brake noise. czwalga00gt 99-04 1 June 23rd, 2007 06:39 PM
2005 auto mustang vibration noise/ rumbling noise ozan169 2005 - 2010 4 March 13th, 2007 05:31 PM
