Discussing Replacing Water Pump in the V6 Mustangs Forum. just wondering how hard it is to change out a water pump on a 96 ...
Old December 19th, 2007, 01:21 PM   #1
6banger96's Avatar
1996 Mustang V6
just wondering how hard it is to change out a water pump on a 96 v6?
Old December 19th, 2007, 03:02 PM   #2
Well since i've never actually done it i cant say for sure but i know gettin the belt off is pretty difficult (was for me anyway). I may be way off base here but i think you may have to take the coolant tank and maybe the fan. Then you get to take out the water pump. Not sure how to do it but i'm assuming that it's not that difficult.
But dont take my word for it because i'm not very mechanically inclined and i have never actually done it. I would suggest investing the money into the repair books. I cannot remember the name of it but i'm sure someone will post it in a bit.
~{BB}~Bored Brothers~{BB}~
ITT Tech class of '09
Old December 19th, 2007, 03:25 PM   #3
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
its about a 6 hour job... off then back on.
take off the belt, a few bolts for things like the coil pack mount, a few other bolts here and there... i would recommend getting a chilton or haynes to help guide you
slow car club - crew member 8 of 9
Originally Posted by omz
Old December 19th, 2007, 05:45 PM   #4
Since you have the 3.8 L v-6.
Other than removing the belt, coil brackets etc. You will also need to remove your power steering pump pulley in order to get off the bracket that connects from the power steering to the water pump. Other than that it should be a pretty straight forward replacement.
FORD= First On Race Day
I'd rather push my FORD than have it towed by a Chevy.
Old December 19th, 2007, 06:31 PM   #5
Onemanzu's Avatar
that is not true... i didn't even have to touch my steering pump when i removed mine
Old December 19th, 2007, 06:33 PM   #6
Onemanzu's Avatar
matter of fact give me a second i will see if you have to with pics provided
Old December 19th, 2007, 06:55 PM   #7
Onemanzu's Avatar
okay... i figured it out... its not true because you can remove the whole steering pump and alternator assembly if you wanted... its a HUGE pain in the ass, and i would suggest that you pull that pulley off
Old December 19th, 2007, 07:36 PM   #8
2000 Mustang V6 n proud
13.1@107mph 2.1-60'
if you have a hard time taking off the serpentine belt then you deffinitly shouldnt attempt this job
the belt is the LEAST of your worries. that takes me about 2min...1 min to walk over and grab the tool 1min to bend down and llift assuming i feel like working slow
it is deffinitly at least a 5-6hour job i'd say.
few things you gotta take off before you get to the water pump first
make sure you have the water pump gasket
how do you know that its your water pump thats bad before you replace it, i'd also go ahead and replace the upper and lower hose and thermostat and gasket
390rwhp V6 mustang stock bottom end
Old December 19th, 2007, 09:51 PM   #9
I didnt have a tool....
Old December 19th, 2007, 09:55 PM   #10
MWWarlord's Avatar
1995 Mustang convertible
Hey guys I've never done this and I'm not sure all that is involved, but pep boys replaced my water pump and thermostat in about 1 and a half hours. It seems to me like it shouldn't take 5-6, but like I said I'm not an expert. Also it might have been easier in my '95 than in the '96. Although I wouldn't think there would be that much of a difference. Again, I am by far not an expert so I could be wrong.
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old December 19th, 2007, 11:32 PM   #11
97TunedMustang's Avatar
for a 96 v6 alldata quotes 1.9 hours,add 0.2 if a/c equipped.
And luckily since i'm so awesome, this equals good things for you. should clear up the confusion...
And some larger versions of the two pics from above^
http://img295.imageshack.us/img295/2...1807983ac9.gif
http://img265.imageshack.us/img265/3...1807984kr8.gif
awesome? i think so
New block with forged internals running 16psi, tuned by Lasota Racing
Too many mods to list...
3.73's and Truetrac Finally Done!
Water-methanol injection?
Dyno Tune fo sho, Street tune FTL!
Old December 19th, 2007, 11:37 PM   #12
MWWarlord's Avatar
Yeah, I thought 5-6 hours seemed a bit long. +rep for 97TM good post man.
MWWarlord
Old December 19th, 2007, 11:42 PM   #13
Onemanzu's Avatar
for a first timer it will take about 3 hours to get it off and 2 to get it back on...
time really flys when your under the hood
Old December 19th, 2007, 11:46 PM   #14
sure does. mechanics who know what theyre doing can do it in 2hrs. The average joe probably closer to 4 or 5 but it just depends on your level of expertise and how efficient you are while working lol.
and no prob warlord
Old December 19th, 2007, 11:47 PM   #15
Onemanzu's Avatar
all im saying is when i TRIED to do my timing cover swap it took me 2 weeks to get down to the cover, and 2 months of staring and prying...
just take your time do it right
Threads Similar to: Replacing Water Pump
Replacing Fuel Pump juan310 V6 Mustangs 22 November 21st, 2007 03:16 PM
Water pump 90Stang 5.0 Mustangs 13 July 8th, 2007 04:57 PM
what water pump 95wip 5.0 Mustangs 2 June 25th, 2007 12:04 AM
water pump 95wip 94-95 6 May 23rd, 2007 09:03 AM
Replacing An Oil Pump Without Pulling The Motor JamesR1 5.0 Mustangs 1 September 17th, 2006 01:57 PM
