valves and or lifters?
So my engine is making a nice ticking sound and the car shakes while its sitting in gear, kinda like its gonna die but the idle rpms are fine, and it does a lil shake when accelerating from a stop. Also just about all my low end power is gone, and the car doesn't really accelerate for crap at all now. I was thinking exhaust leak, but couldn't find anything myself. I took it to an exhaust shop and they didn't find anything either. They mentioned valves or lifters or something in the valve train. How bad is that, or do you think it could be something else
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
48.47@ 12.58
try a can of seafoam
¡ʇsnq ɹo uʍop ǝpısdn
seafoam the vacuum to see if there is an exhaust leak... this will help eliminate that factor/option
04 Mustang
may be the injectors are clogged also. there is a handful of things. is the car throwing any codes?
![]() Sponsor: Chips V6 Specialties < 2004 238C.I. 3.9L V6 Mustang Dual Exhaust,Shaved GT Bumper,Tinted Lights,8000K HID Kit |
Well I had the exhaust looked at its not leaking, and I can hear thwe tick in the front of the engine somewhere. Also I put some fuel systemn cleaner in and engine oil treatment along with an oil change. its not quite as bad as it was friday
Bump...also I seem to be running lean and rich at the same time according to the neew codes being thrown
The soul stealing Ginger
i have the same problem with my car, everyone thought that it was an exhaust leak so everybody at work looked at it, (work at autozone) in the end they couldnt find anything but then i took it to one of my friends who works at a garage and he said it was one of my injectors tapping really freakin loud, take a stethoscope and stick the metal part on the tip of each injector and see if one is louder than the other, they also thought it was lifters but after a couple marvel treatments and seafoam and numerous other additives, it didnt do anything so it wasnt lifters.
#8 | |
check your 02 sensor. your running crappy because its switching from rich to lean like that. if you had a bad injector it would be a lot more prominent, also give your egr a look at. make sure none of the houses collapsed internally
Its actually two codes at once, and where would these hoses be located? on a sidenote after driving the piss outta car on a 300 mileround trip to gallup its nt shaking as bad
#10 | |
WOW ur alive...
could you post the codes? nice to see ya bro!! its been so much time
Yah no internet at home so I gotta post at work...the codes i left in the car: p1181 and 1182 lack of sw...something i think...they meant system lean and system rich respectively
#12 | |
thats ur prob..
have u made a tune or something? change the fuel filter, run some seafoam and fuel system cleaner
That tune has been there since I got the tuner...I ran some fuel system cleaner, and where do I put the seafoam in at
Threads Similar to: valves and or lifters?
| Lifters Going Bad | burnout5.0 | 94-95 | 11 | November 6th, 2010 11:40 AM |
| Should i replace the lifters? | jam77 | 5.0 Mustangs | 2 | October 23rd, 2007 09:38 PM |
| sticking lifters | stephen | V6 Mustangs | 1 | October 18th, 2007 11:48 AM |
| Solid lifters | JBIGBOOTSY | 5.0 Mustangs | 4 | September 21st, 2007 01:39 PM |
| Changing lifters | cams-shelbycobra07 | General Tech | 6 | August 5th, 2007 10:04 PM |
