Boost Gauge
Old December 25th, 2007, 02:43 PM   #1
mmvi is on a distinguished road
Send a message via AIM to mmvi
Boost Gauge
where to run the boost line on a 99 3.8 mustang? should I go directly from the discharge tube or go to the vacuum line behind the tb?
Old December 25th, 2007, 02:46 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
i did mine on the vacuum line
Old December 25th, 2007, 02:49 PM   #3
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
vacuum line behind the TB
is where mine is
[SIGPIC][/SIGPIC]
Acmillr loves me
Old December 25th, 2007, 02:52 PM   #4
is that reliable? the instructions I got weren't specific. it showed the T but didn't explain anything. I put one end into the vacuum line, and one to the bpv, and was hoping for the other to go to the gauge. but, thinking about it, is it really that reliable?
Old December 25th, 2007, 03:05 PM   #5
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Vac line behind the TB -
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old December 25th, 2007, 06:16 PM   #6
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
yep what he said, if you run it to the plenum on the supercharger then you will only register 0psi and up but if you use vaccum then youll be able to monitor it all the way from the 20ish psi of vaccum to whatever psi boost you make
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old December 26th, 2007, 12:28 AM   #7
what to do with pcv valve? delete it and put one of those filter things on each valve cover, or run it back into the blah blah blah vortech? I know vmp has a delete kit, but wouldnt I be better off going to autozone and just picking up two filters for like 10 bucks?
Old December 26th, 2007, 10:07 AM   #8
00 V6 & 09 GT
well this is how my set up is
i have 2 T's
first is behind the TB, then the BOV(your BPV) and boost gauge lines hook up to the 2nd T which is hooked up to the first..
actually i'll just take a picture and label it
because i couldnt see how in the hell 1 T'ee would do them all with blocking of the original vacuum tube to the TB
[SIGPIC][/SIGPIC]
Acmillr loves me
Old December 26th, 2007, 10:27 AM   #9
00 V6 & 09 GT
[SIGPIC][/SIGPIC]
Acmillr loves me
Old December 26th, 2007, 10:30 AM   #10
00 V6 & 09 GT
i now realized i didnt label them anyway the bottom thicker hoses connected together by the T is the hose that connects behind the throttle body
the there is a hose that goes to the second T(the higher one)
that connects the boost gauge and the BOV
boost gauge line is on the left BOV hose is on the right
i never thought of this and i dont know why
i think im just going to T the hose connecting to the throttle body and connect that directly to the boost gauges and BOV instead of re-connecting it to the first initial stock hose
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: Boost Gauge
Where to hook boost gauge on paxton nasty92LX 5.0 Mustangs 8 July 31st, 2007 12:17 PM
Boost gauge question?? jam77 General Tech 7 June 25th, 2007 11:33 AM
Boost/Vacuum Gauge troy1000rr General Tech 1 April 21st, 2007 02:51 PM
Vaccuum/Boost Gauge! jerb43 96-98 1 October 22nd, 2006 03:53 PM
Boost Gauge Not Working... Advice? jerb43 General Tech 7 September 20th, 2006 12:48 PM
