Idle Is Whack
Old September 6th, 2006, 06:09 PM   #1
00SoSlow's Avatar
00SoSlow is on a distinguished road
Send a message via AIM to 00SoSlow
Idle Is Whack
I tap the gas, and my idle runs up then drops to 500 and goes up and down for a lil bit then returns to normal after 5 secs or so
is this becuase i have so many aftermarket parts with no tune to have them all work together or what is the problem
2000 V6 Performance Red @ Cardomain Was fun but a waste...
1987 LX Hatch | Soon to be a 600hp monster
Old September 6th, 2006, 06:42 PM   #2
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
probably iac
ModdedAutos
1999 Mustang V6
Old September 6th, 2006, 06:44 PM   #3
00SoSlow's Avatar
it also seemed to do this after i put my intake on? is that anything i could have budged?
Old September 6th, 2006, 06:46 PM   #4
14.79 @ 92.15
the MAF
ModdedAutos
1999 Mustang V6
Old September 6th, 2006, 06:47 PM   #5
00SoSlow's Avatar
would i need to clean it or what could the problem be with it?
Old September 6th, 2006, 06:50 PM   #6
14.79 @ 92.15
not sure man. does the car run strong through all the gears?
ModdedAutos
1999 Mustang V6
Old September 6th, 2006, 06:52 PM   #7
00SoSlow's Avatar
it seems when i shift its a harder change but other than that it runs great... its just the idle is wierd when i tap the gas... idk i guess id have to tune it or just drive it the way it is
Old September 6th, 2006, 06:55 PM   #8
14.79 @ 92.15
when did it start and what have you done right before it started?
ModdedAutos
1999 Mustang V6
Old September 6th, 2006, 06:57 PM   #9
00SoSlow's Avatar
i really noticed it after i put the intake on... i reset the computer and all needed, i don't know if it was the extension i put on to make it fit around my smog pump
Old September 6th, 2006, 11:02 PM   #10
99mustang232's Avatar
99mustang232 is on a distinguished road
you won't need a tune after the cai... did you plug back in the IAT sensor... does it do it when in nuetral in motion or only at a stop? when the idle is fluxing does it seem like it is bogging some?
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old September 7th, 2006, 01:42 AM   #11
00SoSlow's Avatar
yes when it drops down seems like she wants to die out but then it only happens when i tap the gas and every once and a while when i come to a light
Threads Similar to: Idle Is Whack
IDLE GOES UP AND DOWN WHY? GTSHAYE$ 94-95 2 May 9th, 2007 11:30 AM
idle...... sivart 5.0 Mustangs 4 April 26th, 2007 01:09 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 04:11 AM
Alignment out of whack on a perfectly fine Roush Stang OZ General Tech 2 August 29th, 2006 03:08 AM
need help my 88 won't idle smokin' joe 5.0 Mustangs 2 August 25th, 2006 03:59 PM
