Discussing My Mustang Has A Problem in the V6 Mustangs Forum. I have an 01 Mustang I bought it about 5 months ago And everything was ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Look Ma! My First Post!
My Mustang Has A ProblemI bought it about 5 months ago And everything was fine except the window is kinda jacked up But that's not my point of concern As of recently the performance has dwindled On occasion when I start it and accelerate, it will chug a little But it is very minor Then I'll cruise along And almost like clockwork as soon as it hits 3rd gear It begins to chug a bit Now the chugging seems to get worse when going uphill But once it gets higher rpms in 3rd gear, the problem disappears And fourth gear is smooth The engine doesn't make any obscene or awkward sounds my buddy and I checked the spark plugs and everything appears to be in tact The chugging almost feels like it's not getting enough gas But I am no mechanic So any help on the matter would be appreciated |
Mustang
if you don't think it's not getting enough gas, then an injector might be clogged, or giving out? depending on mileage, and maintenance, a lot of things cross my mind...
1999 Cobra 3380 of 4040 BBK Longtubes BBK Offroad H SLP Loudmouth II Resonators H&R Lowering Springs FS: BBK CAI Coming soon: kb 2.1L |
2000 Mustang v-6
clogged fuel filter?
2000 V-6 Coupe Mustang, 17 inch rims, custom hood, exhaust is done!! |
Mustang
try a tune up and whatnot first before you do anything else.
1999 Mustang GT
Does it give you problems when starting or does it fire right up?
2003 mustang gt
mine did the same thing awhile back and i changed the fuel filter and sparkplugs and its ran fine since check the obvious things first its usally what it is
bbk shorty headers,bbk o/r H, bbk udps, 75 tb&p tri ax shifter, flowmaster catback, k&n cai, diablosport tune (next 4.10s) |
1999 Mustang GT
I'm thinking it's a clogged filter. Try running a strong cleaner, some seafoam and then replace the fuel filter.
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
seafoam the car, and replace your air and fuel filter
![]() Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS MM 4 Banger club: Senior Ricer "Horsepower sells cars, torque wins races." -Carroll Shelby Thanks To My Sponsors: Strup Performance |
1997 mustang v6
slow
i ran my car without a thermostat for awhile and it would do that so maybe youre car is running too cold or something
2000 V6 Coupe
Does it do it at a peticular throttle amount(i.e. 1/4 3/4 barely touching)? Is it only Third that it does it in? If you floor it does it bog or is it ok? Is your ignition coil pack original to the car? If you can answer these I can help ya out.......
1997 mustang v6
slow
well my car started doing the same thing again and it has a thermostat now so it must be something else and for mine it does like 3/4 of the way the down its like when i really push on it that it does it
its also weird cause i ran the heater last night cause it was cold and it didnt do it at all so i dont know if that has something to do with it |
#12 | |
2000 V6 Coupe
One last thing, please don't run your car without a thremostat in it again. The water pump gets the coolant moving so fast that it needs the thermostat to slow it down so it can absorbe some of the heat from the motor, when you take it out it goes through the motor too fast and the cylinders are a lot hotter (50-60 degrees F) then the coolant! If you do that for too long you will blow a head gasket and warp the head. All that I can say at that point is congraz on the $1000.00 you just threw away, and that's if your lucky. Hope that helps..... |
#13 | |
1997 mustang v6
slow
Threads Similar to: My Mustang Has A Problem
| Mustang problem | mikerm125 | 96-98 | 2 | September 10th, 2007 10:51 PM |
| 89 MUSTANG 2.3 NO POWER PROBLEM | mikeym | V6 Mustangs | 18 | June 23rd, 2007 11:24 PM |
| Having an electrical problem with 99 mustang | PRODUCTZER01 | Electronics | 3 | April 8th, 2007 04:48 PM |
| New Problem With The New Mustang Already... | KIMMER | 2005+ | 11 | December 3rd, 2006 01:25 PM |
| 95 Mustang Over Heating Problem | lil_homie69 | V6 Mustangs | 2 | October 27th, 2006 07:12 AM |
