12.8@109
Cam And Heads Installed Now A Wierd Noise From Intake?
Helping a friend of mine install his cam and heads. Long story short...
Got it all done and buttoned up but now there is a strange sound coming from the air intake. Sounds like a tuba!! LOL (sorry buddy). We took the thing apart and put it back together a few times and can't seem to figure it out. New parts are port and polish heads, new cam, new adjustable rockers. Almost sounds like a gasket vibrating but we have double checked those with no luck. Any idea's?
2002 True Blue Mustang GT M5 309 rwhp 320 rwtq tune by Big Shot Dyno Best: 12.8 @ 109 mph 2004 Cosmos GTO M6 (1 of 366) 530 RWHP 510 RWT Tuned by Back Street Performance Best: 11.33 @ 129mph |
srry buddy i wouldnt know....but tell me how much hp or a differnce u get
1999 Ford Mustang V6
what year stang is this... have heard of some getting a strange noise after installing the IAC backwards... but also when you say air intake are you talking about noise coming from the manifold or from the intake air tube? did you recheck the vac lines
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
also what type of rockers did you install? 1.73 adjustable rollers?
12.8@109
It's a 2002. The noise is generated from the the manifold I believe. We have checked all the vacum lines. Took the CAI off and you can still hear it from the throttlebody. We also to the egr off and still made the noise. Checked the brake booster as well. Taking the upper and lower intake manifolds off again to check for the third time...
Any additional thoughts on what to check? Not sure on the Rockers...Comp Cam (for sure) 1.73 (not sure)
would probably put money on the IAC causing it, have heard this once on an explorer 4.0L and it sounded very similar to someone blowing across a beer bottle. i would try cleaning it to see but if it doesn't change replace it.
12.8@109
Isn't the IAC on the CAI elbow? If so we took that elbow off (yes no maf, dangerous) and it was still making the noise through the throttle body. One other odd thing... when the car is cold (first start) no noise for a couple minutes until the car heats up and then it starts and stays. Seems to go away momentarily when you punch the throttle (engine sucking air).
the IAT (intake air tempeture) sensor is on the CAI tube, the 99-04 3.8L mustang IAC (idle air control/bypass) is on the side of the upper intake (near passenger rear of enginebay). here is what mine looks like, yours is the same:
IAC pic1 IAC pic2 there is a gasket if you are careful sometimes it can be reused. also see: http://www.moddedmustangs.com/cleaning-your-iac.html
12.8@109
Going to give it a whirl. Let you all know how it goes.
12.8@109
OK, the problem turned out to be the IAC like you suggested so thank you very much for your help. The tuner had to adjust it when he tuned the car. You guys asked for the results so here they are....
228 rwhp and 238 rwtq Tuned by Big Shot Dyno out of Akron, Ohio. I'll post his track times with it after Sept 18th (we'll be up at Norwalk running them)
nice....what other mods did he have tho...AB almost has that much hp and hes got bolt ons...idk if it rwhp tho..but yea what other mods does he have then?
#12 | |
12.8@109
He has CAI, shorty headers, UDP, Dual exhaust, Triax shifter, tuned by Big Shot Dyno.....I think that is it. You can see his info over on www.buckeyestangs.com
Threads Similar to: Cam And Heads Installed Now A Wierd Noise From Intake?
| wierd from noise | noppe180 | 96-98 | 5 | October 28th, 2007 02:26 AM |
| Wierd Noise..please help | tmab11 | V6 Mustangs | 1 | October 14th, 2007 06:48 PM |
| wierd grinding noise | G.T. Rags | 96-98 | 45 | September 14th, 2007 11:39 PM |
| Wierd noise...help plz if you can | Danny01gt | 99-04 | 15 | January 13th, 2007 12:19 AM |
| wierd noise suggestions? | 02NEBstang | 99-04 | 2 | December 22nd, 2006 08:29 PM |
