Modded V6
![]() iTrader: 1 reviews
Auto transmission removal please help me
I'm in the middle of putting a new transmission in my cousins mustang but I'm having a problem with the torque converter bolts...the ones that are bolted onto the flywheel. They just won't come off. I've tried clamping the flywheel and having my dad get the bolts off but that didnt work. They are super tight and are rounding. Theres not enough room to cut the bolts off. Is there anyway i can get the tranny off without having to undo the bolts? Any suggestions are appreciated.
BTW if it matters this is for a 2000 v6
![]() 1999 e46 328i BMW - Daily Driver 2001 SVT Cobra - Project 1995 v6 vert - SOLD 1996 v6 vert - SOLD 1995 v6 vert #2 - SOLD 1995 GT - SOLD 1997 v6 coupe - Parting |
2007 Mustang GT/CS
ok, get some dynamite and blow them out of there. thank me later
![]() 2007 Mustang GT/CS 5spd: Flowmaster hushpower axle back,O/R X pipe,JLT CAI,93 Bama tune..laser interceptor dual jammers, Escort Redline RD,Laser Veil G4. |
04 Mustang
do they look rusty? try pb blaster to get the rust off, i used that on a rusty o2 sensor and it worked wonders.
if its not coming out and its starting to strip stop trying to get it our because if you do strip it your screwed edit~ you can find pb blaster at pep boys or any automotive store
![]() Sponsor: Chips V6 Specialties < 2004 238C.I. 3.9L V6 Mustang Dual Exhaust,Shaved GT Bumper,Tinted Lights,8000K HID Kit |
MM's Resident Ricer
2006 Scion tC
13.001@113
wd-40 the crap out of them, and if that dont work ratchet gun
#5 | |
If all else fails you can pull the transmission off with the torque convertor still bolted to the flex plate; though, this isn't recommended since it might damage seals. With the trans off you would have more room to deal with the stuck nuts. Perhaps a nut splitter would work. |
2005 Torrid Red GTO m6
got an air compressor?
use an air cdompressed ratchet.
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. |
Those bolts are thread locked and pretty much designed not to come off. Use as long a breaker bar as you can and replace them with new when you put it back together, and dont forget the thread lock.
2003 V6 Automatic Ebay CAI Soon to be for sale. WTB 2003 Cobra with 75000+miles OR 2003 GT w/<50000 miles |
it'll be VERY hard to get them out
they should have a thread locker on them i believe. not to mention about at least 80ft lbs of torque or around that area. it needs every bit of it. ive tighten flywheels and torque converters to manufactor specs and the bolts still come loose. a thread locker of some sort is needed. you will need a big pole to go on to your ratchet. i'd use a 1/2 ratchet no doubt, and the biggest longest ratchet you have and a pole
#9 | |
You should be able to lock the crankshaft using a socket and breaker bar on the crank pulley bolt and get the torque convertor nuts off with a 6 point socket and breaker bar after soaking them in penetrating oil overnight. If nothing else this should break the studs off the torque convertor, which at least gets it apart. Another option is to split the nuts with a chisel after which they will come off easily. |
1995 Civic EX
Soon to see a Garrett 60 trim
Ok I had to pull a pressure plate off an old dodge pickup and what I did is use a 12 point metric socket small enough to hammer and force over the head of the bolt and breaker bar'd that beeotch.. It's not the best thing to do to a socket but I only own Craftsman tools anyway.. Free lifetime replacement
My honda |
Threads Similar to: Auto transmission removal please help me
| Help - Transmission Gear Removal? | 99pehrsc99 | 2.3 Mustangs | 5 | January 9th, 2008 12:52 PM |
| transmission removal | captain_communism | 99-04 | 17 | October 8th, 2007 07:49 PM |
| Transmission removal | energiesource | 99-04 | 3 | July 28th, 2007 04:57 PM |
| Auto Shifter Handle Removal?? | TonyNDeb | 5.0 Mustangs | 1 | November 22nd, 2006 10:50 PM |
| Auto Transmission Question | CyberPrey | V6 Mustangs | 7 | November 13th, 2006 05:03 AM |
