Discussing Bleeding the Cooling System in the V6 Mustangs Forum. Anyone has any idea on how to bleed the cooling sytem? Any feedback is appreciated. ...
Old January 2nd, 2008, 08:11 PM   #1
Thank You
FORD= First On Race Day
I'd rather push my FORD than have it towed by a Chevy.
Old January 2nd, 2008, 10:00 PM   #2
97TunedMustang's Avatar
Fill the car with rad fluid till you see it start to get near the radiator fill neck. Then start the car and wait for the thermostat to open which wont happen till the cars pretty much fully warmed up. Make sure the heater is OFF during this step. You'll feel hot coolant flowing through the top radiator hose when this happens and you should see the coolant level drop in the radiator, and if you look in there you should also see the water in there circulating around. Once this happens add more coolant till its about full again, then go turn your heater ON at full blast. Wait a few minutes while the air bubbles get out and the heater core is refilled with coolant. You will also want to add more coolant once you're done with this step. Once the heaters blowing air like its straight from the fires of hell cap off your radiator, and let it run a few more mins. Then go ahead and shut 'er down, give yourself a pat on the back, and grab a beer.
New block with forged internals running 16psi, tuned by Lasota Racing
Too many mods to list...
3.73's and Truetrac Finally Done!
Water-methanol injection?
Dyno Tune fo sho, Street tune FTL!
Old January 2nd, 2008, 10:40 PM   #3
Thanks for the quick response. I appreciate it.
Old January 3rd, 2008, 12:55 PM   #4
There is a bleed plug to facilitate this. It's located on the tube that comes out of the water pump. Remove that plug and add coolant to the radiator till it overflows and then install the radiator cap and add coolant through the tube till it overflows and reinstall the plug. This will get most of the air out.
Threads Similar to: Bleeding the Cooling System
moping up the cooling system usmcsawgunner 5.0 Mustangs 4 July 2nd, 2007 02:28 PM
07 cooling system upgarde dumps 2005+ 2 May 29th, 2007 11:03 PM
whats the best cooling system CLEANING method before........ 95oldyeller 5.0 Mustangs 1 February 13th, 2007 08:12 PM
96 GT Cooling System Upgrade ?'s Areteracing 96-98 5 January 15th, 2007 11:50 PM
General question on brake system issues (bleeding/no pedal) 95plainjane General Tech 3 July 4th, 2006 12:22 AM
