LinkBack (1) | Thread Tools |
#1
99 Mustang fuel pump problem?
This morning the Mustang started and ran very rough for a moment then died and now won't start. I suspect a fuel pump problem.
I haven't noticed before, but when I turn on the ignition switch I understand I should hear the pump run for a few seconds. Should I listen at the fuel pipe with the cap off? I know there is an inertia switch in the trunk left side also there is evidently a fuse. Anything else to check if the pump isn't running? I understand that starting in 99 there isn't a fuel pump relay, but some sort of a control module. Anyone know where that is located? |
48.47@ 12.58
I would swap out your fuel filter first.
if you can hear the pump turn on odds are that is is working.
¡ʇsnq ɹo uʍop ǝpısdn
check your fuses relays and switches to make sure that they are all good... after that check to make sure that you can hear the fuel pump ... if everything is quite its really easy to hear... sounds like a very small electric motor and should only last 1-3 seconds...
An update.
I found I could hear the fuel pump running and fuel pressure appears normal at 45 psi. I found that there was only intermittent spark on some plug wires and none on others. I removed the plugs and they all smelled like gasoline. I plan to replace the coil, wires, and crank angle sensor and see if that helps. |
check your oil just to be sure that any unburnt fuel didnt get forced past the rings into the crank case. my escort did this and it fucked the whole bottom end. i had a plug electrode fall of mid cruse didn't notice till i parked it and tried to restart it.
#6 | |
as for the problem in the thread one way to check the fuel pump if that is it have someone try to start the car and bang/hit the middle of your gas tank (thats where your fuel pump is) if it starts more then likely something is wrong with your fuel pump i'd change the fuel filter first though and at least check the spark plugs and spark test the wires if your spark test the wires and dont see a BLUE line(electricty) the wire or coil is no good if you try new wires first and still dont see the blue line more then likely your coil is no good. i'd just grab a screamin demon coil since its about the same price or cheaper then OEM from ford or an auto store i believe
#7 | |
As I said, I found normal fuel pump pressure and gas on the spark plugs, so I think I'm getting normal fuel delivery. I checked for spark with an inductive pickup timing light. It definately indicated intermittent spark on some wires and none on others. I replaced the coil and saw no change. I will replace the wires next. The first set I got were not the correct wires, but I swapped them for a set that seems to be right. I also ordered the crank angle sensor. |
1993 5.ohhhh
12.97 @140mph
My car did that for a while I changed my fuel filter, and it ran shitty like twice after that but eventually it just stopped.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
It's running again, but I'm not really sure what was wrong.
I replaced the coil, wires, and crank angle sensor and it still was cranking and trying to start but wouldn't go. I was going to have it towed to a shop and the tow truck driver cranked it for some time and got it going again. His diagnosis was water in the fuel which is consistent with the hard rains we've had around here. I added a can of Heat to the gas and will run out the entire tank of fuel. Hopefully I won't have more problems. |
thats some weird shit man
The last couple months, my v6 mustang has been acting weird, idling funny, low performance, and sometimes wont start at all. I've had to have it towed home recently, and after wearing out the battery trying to start it, i've noticed that just letting it sit for a few hours, then it will start fine... This really has me bugging.... I've called ford tech's, they've had me search here and there, check this and that, but the bottom line is i can get the darn thing to start, after 3 hours has gone by when it wont start... I've been told the fuel pump is going out, i've been told to change my fuel filter, change your wires, your spark plugs, check your fuel pump reset switch and fuse's, OMG where does it end... Every time i check these things, all seems fine... No matter how long i crank the engine, it wont start, UNLESS I WAIT 2 TO 3 HOURS, then it starts fine like there was never a problem.. I SCREAM AT IT, KICK THE TIRES, YELL ALOT, IT'S REALLY DRIVING ME INSANE, AND MY NEIGHBORS ARE STARTING TO DISLIKE ME!
anyone got any ideas? when a fuel pump goes out, DOESN'T IT JUST GO OUT??? One neighbor saw the problem I was having, and shook his head, ahh it's never gonna start, your going to wear out the starter, (I agreed with him) and stopped cranking the engine, it's rather annoying... and a few hours later, went out there and it started right up, he yells "hey what did you do" i said "NOTHING AT ALL" he said ahh b/s, I said no, really, i didn't do anything... This car is starting to really drive me nuts, someone please help me!!! |
#12 | |
1998 Mustang
-Mods- rebuilt 7.5 rear, posi, 3.73's, 245/55/16 sumi racers, CAI -Future- 4.2L swap, ported lower, windstar upper, UDP, Tune, dual exhaust, short shift kit...etc |
'00 V6 Procharged Mustang
Fuel pumps can be intermittent when they start to go, it usually depends on what position they are stopped in. They're easy enough to replace and upgrade even.
Why are you two asking stuff in a thread that's over TWO YEARS OLD.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
1998 Mustang
i saw it pop up and replied because he had a similar problem with fuel pump. lol
99 V6 BASE
NEVER RACED THIS ONE
AGAIN another old thread pops up with itschristorres8 in it. Whats up with that
1998 Mustang
lol
Ok the car did it again, crank, crank, crank(for about a minute, then gave up) finally i noticed the THEFT LIGHT ON, blinking like it was being STOLEN, so i slammed my hand on the dash (THEFT LIGHT STOPPED BLINKING LIKE CRAZY), and the damn car started right up and ran fine... all these months of thinking the fuel pump was going out... turns out the fuel pump is told NOT TO RUN, in the event it thinks it's being stolen (SO IT WAS JUST DOING IT'S JOB.) So what would this be? a bad ground in the dash, or the ignition key switch?
-So at-least I know what to do if it ever does it again!!! Wish I had known that the last time when I had to have the darn thing towed home.. |
#18 | |
Now I don't know what caused that, but my remedy was brute force, and being a little pissed, so I slammed my hand on the dash right above the key, the light stopped blinking erratically, and went back to normal mode, as it did that, i heard that familiar WHINE, (the sound the fuel pump makes when pressurizing) and the car started right up... hope it helps
#19 | |
If you have a spare key try using that for a while and see if that happens again. Every once in a while you see someone's key die on them.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/49194-99-mustang-fuel-pump-problem.html
| Fuel Pump Relay On Ford Mustang | This thread | Refback | October 7th, 2010 01:24 PM | |
Threads Similar to: 99 Mustang fuel pump problem?
| Fuel Pump Wiring Problem | Black Five 0h | 5.0 Mustangs | 3 | December 25th, 2007 12:32 AM |
| Fuel Pump Problem? | chaosstangman | 5.0 Mustangs | 3 | December 19th, 2007 11:39 AM |
| 42lb Injector & Fuel Pump Install Problem | hardhitter | 99-04 | 22 | November 22nd, 2007 09:17 PM |
| Fuel Pump Problem | RyanGT | 99-04 | 2 | November 11th, 2007 03:18 PM |
| 1990 Ford Ranger XLT fuel pump problem | ScyraxxX | All Other Vehicles | 22 | August 9th, 2007 02:15 PM |
