Car killed while driving and wont start now
Old January 5th, 2008, 10:34 AM   #1
99v6stang's Avatar
99v6stang is on a distinguished road
okey so i was just driving along and all of a sudden my car killed. I coasted over to the side of the road and tried starting it again, all it did is just barely make a click then nothing. Yet the headlight and radio still worked fine. I tried jump starting it but still nothing. So i figured it cant be a starter problem because that wouldnt kill the car, it cant be the alternator cause that would have drained the battery, the connections are tight. So possibly an ignition fuse or what? i ned helo fast because i cant leave my car there for long.
My car ---- (m112 in progress)
Old January 5th, 2008, 11:08 AM   #2
MM's official Chevy guy
2002 Mustang V6
whitemustang02 will become famous soon enoughwhitemustang02 will become famous soon enough
Send a message via AIM to whitemustang02 Send a message via Yahoo to whitemustang02
if it is in a bad spot then i'd say get it towed to ur house or somewere close that u can feel safe leving the car.
then start cheking batery cenections.
also how long have u had the 4.2 in ur car
"Speak softly and carry a big stick" - Theodore Roosevelt
"Any idiot can make a V8 fast, it takes a real idiot to make a fast V6".
'02 Mustang N/A 4.3 stroker away for winter
'72 Chevelle project car 454 coming
'93 Bronco EFI 351W DD
Old January 5th, 2008, 11:10 AM   #3
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
BAD GROUND! check your terminals and see if they are lose. my tempo did this to me weekly. i just wiggled the ground and off i went. however i recommend you fix this rather then ignore it like i did.
Old January 5th, 2008, 11:23 AM   #4
99v6stang's Avatar
Ive had the 4.2 in for about 2 months. And it wouldnt be the ground would it, because the battery still has plenty of power and powers everything else in the car.
Old January 5th, 2008, 11:29 AM   #5
Juggalo_X's Avatar
14+@Slow
bad grounds do some weird shit man im just tellin yah form experience my tempo did the EXACT same thing. everything thing worked but no crank. it was a badly attached neg battery cable.
Old January 5th, 2008, 11:31 AM   #6
2002 Mustang V6
id say go through and check the conections somthing may have come lose from when u did the swap.
Old January 5th, 2008, 11:45 AM   #7
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
loose neg, battery cable like jugg said, cause your not getting enough power to turn your flywheel if your only getting one click
NCMM #9
Old January 5th, 2008, 12:27 PM   #8
99v6stang's Avatar
but the connection is very tight, i can lift the battery out of the car by pulling on the cable.
Old January 5th, 2008, 12:29 PM   #9
Juggalo_X's Avatar
14+@Slow
whats about the to engine and chassis ground? could be tight on the battery side lose on the other.... its showing characteristics of a pooched battery or a bad connection.
Old January 5th, 2008, 12:29 PM   #10
MM's Resident Ricer
2006 Scion tC
13.001@113
well it may be in the actual neg, battery cable. buy a new cable and see if that fixes it, but something killed your alt if it just died like that and your battery isnt strong enough to run the car
NCMM #9
Old January 5th, 2008, 12:35 PM   #11
Juggalo_X's Avatar
14+@Slow
this is true. i think he has a bad connection in the charging circuit, probably ended up runnin his battery down and now it wont turn over and the alt isn't charging correctly. get a boost if u start u know its a ALT charging issue and your batter is flat. like i said this is commonly caused by a bad connection, or ground. but also could be straight up ur ALT failed on yah.
Old January 5th, 2008, 12:59 PM   #12
99v6stang's Avatar
like i said before i did try jump starting it and it still wouldnt start. It did the exact same thing still. Where is the engine ground located? it is about 20 degress out so i dont want to spend all day looking for it
Old January 5th, 2008, 01:20 PM   #13
RhadCundell's Avatar
RhadCundell is on a distinguished road
Send a message via AIM to RhadCundell
..have you tried gas????
Old January 5th, 2008, 01:22 PM   #14
99v6stang's Avatar
have you tried reading any of this thread? The car wont even turn over at all, i turn the key and nothing happens, so gas is not an issue here.
Old January 5th, 2008, 01:24 PM   #15
ive ran out of gas..like completly
and nothing happens at all
everything works fine..
try turning the key sounds like the battery is dead..
Old January 5th, 2008, 01:29 PM   #16
99v6stang's Avatar
well i cant imagine the starter not turning because the car is out of gas, and i would have seen the gas light come on.
Old January 5th, 2008, 01:31 PM   #17
Juggalo_X's Avatar
14+@Slow
+1 its not a fuel issue. this is electrical and it has to do with the charging circuit
Old January 5th, 2008, 01:31 PM   #18
oo
yea i don t have a gas light..
so i didnt think about that
Old January 5th, 2008, 01:37 PM   #19
99v6stang's Avatar
But are you sure it is a problem with the charging unit, becuase if that was the case wouldnt it still start with the jump start?
Old January 5th, 2008, 01:51 PM   #20
Juggalo_X's Avatar
14+@Slow
nope. my sunfire had a battery that was totally fucked form a bad charging circuit and it wouldn't boost at all. the battery just over heated the longer i had the booster cables on it .
Threads Similar to: Car killed while driving and wont start now
car wont start Black Five 0h 5.0 Mustangs 8 January 4th, 2008 03:12 PM
Car Killed And Now Wont Start 99v6stang All Other Vehicles 25 December 5th, 2007 02:08 PM
96 GT wont start Mystry 96-98 6 March 17th, 2007 01:25 PM
Car wont start 99v6stang V6 Mustangs 41 February 20th, 2007 10:08 PM
Need Some Help - Car Wont Start ANoXiA 2005 - 2010 6 December 23rd, 2006 06:07 PM
