v6 starting problem
Old January 6th, 2008, 01:32 PM   #1
xNOILABOYx is on a distinguished road
Unhappy
v6 starting problem
first offf, I have a 99 v6 stang
So, when i turn the key i get my system lights for about a secong and they fade off. It will click once or twice and then nothing.
When i try jumping it, the lights stay on the gauges sweep and stay normal,radio and everything work, but i still get one or two clicks, nothing else
Any help would be greatly appreciated, I think its the starter but i have no clue. thanks
Old January 6th, 2008, 02:52 PM   #2
modded232's Avatar
2000 Mustang V6 Vert
modded232 is on a distinguished road
is it cold where you live?
my guess would be your battery is just very low on charge
try boosting it again and if it starts turn radio and everything electrical off and go for a good drive
Old January 6th, 2008, 02:58 PM   #3
modded232's Avatar
also when you try to jump it make sure the terminals on the batteries of both cars are clean, the jumper cables are good quality, and make sure you are revving the working car (i usually just hold it at 3k rpms) when you are for a bit before and while you are trying to start the dead car
Old January 6th, 2008, 02:58 PM   #4
2004 Mustang V6
04DSGV6 is on a distinguished road
How olds the battery? If old as car or not recently replaced thats probably your best bet. Take it to an auto parts store. Most of them will tell you if its bad or needs a charge and some places will even charge it for you. I sincerely doubt it would click at all if the starter was bad and the lights would light up if the starter is bad and the battery is good.
Old January 6th, 2008, 03:26 PM   #5
Shake N' Bake
supermachone's Avatar
1984 Corvette
Kessel Run @ Less Than 12 Parsecs
supermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to all
you probably have a bad ground wire on your battery, try replacing it
BONER CREW EMPLOYEE - PACKAGE INSPECTOR #1
Old January 6th, 2008, 03:31 PM   #6
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
i say put it on a charger for a while...def. ur battery gone dead
SCT Mass Air Flow Sensor $200
Old January 6th, 2008, 04:26 PM   #7
wow thanks alot guys, it was pretty cold last night but it just started up after a few clicks now. Im goin to get the battery tested at peps
Old January 6th, 2008, 05:31 PM   #8
blazor's Avatar
blazor is on a distinguished road
Send a message via AIM to blazor
when ur jumping it, try attaching the ground (-) to something else (anything metal), if it starts easy, then its prob a bad ground cable attached to the battery.
-01 V6 Coupe 5 Speed
-02 GT Convertible 5 Speed
Old January 6th, 2008, 05:40 PM   #9
modded232's Avatar
^ battery was frozen/ on the verge of being frozen?? we get that all the time at my work
Old January 6th, 2008, 05:44 PM   #10
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
starter buddy, one or two clicks is the starter
NCMM #9
Old January 6th, 2008, 06:14 PM   #11
so the peps guy says batt and starter tested good but he thinks the bendex? is going in the starter. anyone familiar w this? is working perfect now though, is it just the cold or should i replalce my starter?
Old January 6th, 2008, 06:32 PM   #12
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah it probably is whats wrong with it, on older cars you could just buy a new bendex but you have to get a whole new starter in your case, but thats probably what it is since the starter works sometimes, a good way to tell is the starter will sound like something is wobbleing inside of it when someone starts the car, but you have to listen outside the car for it
NCMM #9
Threads Similar to: v6 starting problem
Starting Problem Reset 99-04 2 November 11th, 2007 03:44 PM
Problem starting up sbx213 5.0 Mustangs 5 March 11th, 2007 11:46 PM
problem starting mustangman0001 5.0 Mustangs 3 March 4th, 2007 01:52 PM
Starting Problem 97_4.6L_Stang Modular Mustangs 5 January 23rd, 2007 10:01 PM
Car Starting Problem In My 03 GT autostang03gt 99-04 3 November 13th, 2006 01:09 AM
