New To The Mustang... Twin Turbo vs Supercharger - Page 2
Old September 11th, 2006, 10:52 PM   #21
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
depends on tune
the more air, the more fuel.
you will need a larger fuel pump, fuel injectors and a larger MAF as well as other misc. things to get it all working, and if you run high boost, you will suffer at the pump.
if you stay in the low rpms and out of boost for the most part, you wont have adverse results
usually, if you have the money to s/c, you have the money for gas
ModdedAutos
1999 Mustang V6
Old September 11th, 2006, 11:03 PM   #22
MustangDrew212 is on a distinguished road
N/A Route...
Ok, if im going the N/A route, what all can i do to my car there? I dont really know much of what i can do other than a port and polish, and that you have to do somewhere and its expensive isnt it? I already have a cold air intake. My exhaust is also a true dual exhaust.
Side note, anyone know how to get rid of the popping sound from my exhaust, it makes it sound kinda like a truck. I find that its only in the higher RPM's and usualy when i let off the accelerator its more noticable... Otherwise under like 3.5 or 4k, it sounds great, got that GT kind of rumble i like, yet still economical.
Old September 11th, 2006, 11:07 PM   #23
14.79 @ 92.15
depends on your mufflers, cats, and pipe sizing/bends to get rid of popping noise. you may have leaks somewhere in the system too...
for the n/a route, check out supersixmotorsports.com
ModdedAutos
1999 Mustang V6
Old September 11th, 2006, 11:09 PM   #24
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
i dont think u can get rid of that popping sound. i have heard GT's with bassani or Borla exaust and wen u let off it makes a diff sound, but with no popping..look at sum videos an u'll see. but i dont think u can get rid of that
porting and polishing is expensive from wat i heard and doesnt give u much gains
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 11th, 2006, 11:10 PM   #25
14.79 @ 92.15
BS. p/p is expensive, true, but can net higher gains than any bolt on mod, and even greater gains with high flowing mods such as forced induction of even long tube headers.
ModdedAutos
1999 Mustang V6
Old September 11th, 2006, 11:16 PM   #26
00 V6 & 09 GT
oh how much would it cost though, and wat kinda hp gains?
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 11th, 2006, 11:22 PM   #27
14.79 @ 92.15
heads and intake about 800-1300 bucks (stage 1-sage 3) to core out stock and receive p/p from ssms.com.
stage 2 adds 70+ rwhp n/a and safe
stage 3 adds 90+ rwhp n/a and safe
add a cam, and a dyno tune and you will be n/a faster than some modded 4.6's
http://www.supersixmotorsports.com/p...2PowerPaks.pdf
ModdedAutos
1999 Mustang V6
Old September 11th, 2006, 11:27 PM   #28
00 V6 & 09 GT
70 hp!!!!
thats sumthin a shop would have to do tho right? or no?
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 11th, 2006, 11:29 PM   #29
14.79 @ 92.15
yes, a machine shop or ssms does it too. they have a n/a v6 running 11's all motor and low 10s on nitrous.
ModdedAutos
1999 Mustang V6
Old September 11th, 2006, 11:31 PM   #30
00 V6 & 09 GT
thats goin on my list
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 12th, 2006, 12:02 AM   #31
99mustang232's Avatar
99mustang232 is on a distinguished road
never said they sell turbo kits, i was posting a few links to the owner of VMPTuning's V6 mustang.
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old September 12th, 2006, 12:07 AM   #32
00 V6 & 09 GT
ohh! my bad.
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 12th, 2006, 12:34 AM   #33
Re: N/A Route...
gears+tlock, UDP's, full exhaust with longtube headers, p/p heads w/larger valves, cam, p/p intake manifolds or sheetmetal upper manifold, valvetrain upgrades, new internals, main girdle, windage tray, tubular k-member, electrical/ignition, tuning
what is your current setup, most v6 mustang exhaust setups sound great in the lower rpm's or idle and raspy in the higher rpms or WOT
Old September 12th, 2006, 01:27 PM   #34
I have dual all the way back... 2 cats, and 2.25 all the way back after the cats, no mufflers, the whole shibang, haha. I just dont like the popping noise that comes out after I let off the accelrator when im at about 4.5k or above, makes a popping kinda sound, someone said something about backpressure or something, would an x-pipe fix this? Im also looking into new high flow cats and bigger exhaust manifolds. And what is WOT?
Old September 12th, 2006, 03:36 PM   #35
14.79 @ 92.15
you not having mufflers will make your exhaust sound like shit. x and h pipe wont change backpressure or equalize any pressures of an even firing essex v6 motor. wot is wide open throttle
ModdedAutos
1999 Mustang V6
Old September 12th, 2006, 10:35 PM   #36
Actualy, it sounds pretty good right now, i took it back to the shop, one side was 2.25 and the other was only 2... so i think it sounds alright so far, i'd rather not have a muffler, unless there is one that has very little HP loss to it, and i really like my car noisy enough to be noticeable.
Old September 12th, 2006, 10:41 PM   #37
14.79 @ 92.15
magnaflow mufflers perform sometimes at 1rwhp less than no mufflers, but increase tq across the curve of no mufflers. stock gt mufflers perform very well too and make more power than no mufflers
this info is gotten from justin who tunes mustangs and is over at v6power.
ModdedAutos
1999 Mustang V6
Old September 13th, 2006, 01:10 AM   #38
I just had what the guy at the shop called flowies, taken off... if i wasted that cash ima be mad... at least ill be getting the tips put on for free...
This good? Ive wanted a 2.5 but the guy at the shop said his bender couldnt do it...
http://www.magnaflow.com/02product/s...merican&id=280
i just wish they had a sound clip and a picture for it...
Old September 13th, 2006, 07:16 AM   #39
14.79 @ 92.15
no that is not good. that comes out of a Y pipe so it is a dual-single-dual setup. you need a new midpipe to gain power
ModdedAutos
1999 Mustang V6
Old September 13th, 2006, 11:37 AM   #40
greaser's Avatar
2008 Mustang Bullitt
greaser is on a distinguished road
FYI anyone interested in more info on the soon to be released X-Charger from Explorer Express for the S197's 4.0, can read about it here (also a video in 1st post)
http://forums.bradbarnett.net/showthread.php?t=46135
Threads Similar to: New To The Mustang... Twin Turbo vs Supercharger
turbo, twin turbo, or supercharger? mustangman87 5.0 Mustangs 31 March 6th, 2010 07:35 PM
HP Twin Turbo Kit or Kenne Bell Supercharger??? HELP! Chris02 99-04 10 January 6th, 2008 12:20 PM
Supercharger, Twin Turbo, and Single Turbo justinsstang General Tech 24 March 7th, 2007 09:07 PM
tma twin turbo, or procharger intercooled supercharger? 94pacecarSVT General Tech 7 February 24th, 2007 12:55 AM
S-197 Twin Turbo Mustang GT JohnnyZ 2005 - 2010 32 January 5th, 2007 12:13 AM
