Intake Question
I have a 99 stang and I recently put on a K&N cold air induction kit. When I was taking it out for a drive to make sure it sounded right, it made a low pitch wistleing noise. But it did not sound as if it was not installed right. Is it supposed to make that noise?
yes it will make a whooshing or a whistling noise. if you have a vacumm leak it will usually bog down unless its before the MAF. just re check your connections and if they all seem square and tight im sure your fine. i have the same noise im thinking its normal. cuz i cant find any leaks and i checked for 20 min last night on mine.
2001 Mustang GT
8.9@78
![]() iTrader: 2 reviews
prop up your hood and with it runing and pull the throttle abit and see if you can pin point the noise.
assuming that all the everything is tight, yes you will hear a whistling noise or whoosing noise.
1998 mustang 3.8l v6
mine makes the same noise. i thinkl it is just from the after market cai
![]() RACING because baseball,basketball, bowling,football, and golf only require one ball |
2006 mustang v6
Ya your fine.
S&B CAI Helix worthless throttle body spacer BBK headers Pypes Hi-Flo Cats Custom dual flowmaster set up SCT X3 4:10 with T-lok |
Threads Similar to: Intake Question
| one last intake question | sonicblue | 99-04 | 13 | April 7th, 2010 12:42 PM |
| intake question | burin_rubber | V6 Mustangs | 8 | July 30th, 2007 11:11 PM |
| Intake question | scxc15 | V6 Mustangs | 5 | June 1st, 2007 10:36 PM |
| Intake question? | 00stang | V6 Mustangs | 6 | January 31st, 2007 12:06 AM |
| Intake Question | JRubin2000 | 99-04 | 4 | September 12th, 2006 10:04 PM |
