angry
so i idle issue i had way back when has sprung up again. ive cleaned the IAC, used electrical cleaner on the MAF, ran injector cleaner, used seafoam, and replaced fuel filter. is there any thing else that could cause it.
oh and side note i was driving down the highway and i decideted to try something: i took my car out of gear (manual) and turned the cruise control on and pushed the set/accel button down and my engine reved up to 4500 before i just put it into gear to make it go away. any ideas?? |
¡ʇsnq ɹo uʍop ǝpısdn
lol i tried that once in my rx7... my car freaked out and wouldn't let me do anything so i had to turn it off then back on ... lol
sounds like you might have a vacuum leak if you checked all those
ive heard many aways to check whats the best way?
replace everything?
i had to replace a few on my rabbit till i found the right one
thats stupid. can i buy all the hoses at autozone or advanced?
MM's official Chevy guy
u should beable ot by ganaric vacum hose and cut it to langht, and befor u go replacing hoping to get lucky i owuld seggest, if u havent already, looking for craks or splits in the hoses and just replace those.
![]() "Speak softly and carry a big stick" - Theodore Roosevelt "Any idiot can make a V8 fast, it takes a real idiot to make a fast V6". ![]() '02 Mustang N/A 4.3 stroker away for winter '72 Chevelle project car 454 coming '93 Bronco EFI 351W DD |
#8 | |
48.47@ 12.58
you were losing speed when you took it out of gear and your cruise control was trying to regain the speed you set it at.
quick question if i disconnect the inertia shut off and purge the fuel lines would i be able to just plug it back in and start my car?? (off topic and i know)
ill go look at the hoses, i was told spraying carb or brake cleaner near the hoses and youd hear a jump in RPMs and that would indicated a leak. yes? |
that just sounds like the stupidest thing ever i thought cruise control only worked if the car was in gear like it had a sensor of something?
48.47@ 12.58
notice how your CC cable is attached to the throttle?
also notice how if you hole the accl up button your gas petal goes down without your foot?
48.47@ 12.58
Don't feel bad.. It happened to me once in my sixer when I had first bought it.
I had the CC on and went to down shift to pass someone without turning it off.. it revved right up before I put it back in gear.
still its stupid
48.47@ 12.58
at least you know no that nothing is wrong with your car
that was only half the battle now i gotta figure out wtfsu with my wack ass idle
BS... the cruise control should turn off when you disengage the clutch if it doesn't ford sucks
48.47@ 12.58
Ford sucks then.
However if it doesn't disengage when you tap the brake you might have an issue.
2000 Mustang V6 Vert
CC should disengage as soon as you press the clutch in, it says in the manual and it works on mine
MM's Resident Ricer
2006 Scion tC
13.001@113
what kind of exhaust work do you have done?
Threads Similar to: angry
| Feeling Angry? Like To Beat Up Kids? | HMUSN | The Clubhouse | 24 | December 21st, 2007 04:40 PM |
| Anyone Remember The Angry Beavers | Drick | The Clubhouse | 64 | November 17th, 2007 12:22 AM |
| Loud Angry Exhaust | trueballerisme | V6 Mustangs | 37 | October 30th, 2007 05:28 PM |
| grr makes me angry | mustang kid 1989 | The Clubhouse | 10 | July 6th, 2007 11:44 PM |
| So angry just got my 4.10's installed! | spero | 99-04 | 31 | July 6th, 2007 12:45 PM |
