#21 |
no problem with switching oils
lets see i went from using royal purple then when i put the turbo in i ran advanced auto parts conventional oil for 300miles no problem
#22 |
MM's Resident Ricer
2006 Scion tC
13.001@113
unchanged synthetic will do just has much harm as conventional, just cause it is harder to break down doesn't mean it wont and oil sitting for a year isn't going to protect your engine as well as getting it flushed and changed every 3 months, also you add oil back when you change the filter right?
#23 | |
thats why its every 3,000 miles OR 3 months which ever comes first! deffinitly always change the oil filter and at least at oil to the seal aroundthe filter and i like to pour a lil inside the filter not changing the filter will build up sludge in the filter itself and everywhere else making the filter useless and can possibily even lower oil pressure and if the oil filter is completely clogged things can get worse if you dont have oil pressure oil may no go to the oil gallies in the engine block and crank the bearings on the crank and rod will then get SO hot they can actually weld themselves together or blow the engine and cause serious over heating issues and then taking apart the engine will be a pain if the parts are welded together from the heat this isnt likely you'd have to run the same oil filter for quite some time like couple years and have no oil pressure and run the car for a while
#24 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
#25 |
1995 Mustang convertible
Is there really that much difference between pennzoil full synthetic and mobil 1 or castrol?
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
#26 | |
Threads Similar to: Synthetic
| Synthetic | Youngin | V6 Mustangs | 43 | August 31st, 2007 11:02 AM |
| synthetic oil ? | Blackbeauty v601 | V6 Mustangs | 6 | July 31st, 2007 10:05 AM |
| Synthetic or Regular Oil | PaperCross | General Tech | 28 | May 2nd, 2007 06:31 PM |
| Synthetic vs. semi synthetic vs. standard | stagecrewgod | General Tech | 2 | March 29th, 2007 09:33 AM |
| Synthetic Oil | TedG954 | 2005 - 2010 | 33 | March 5th, 2007 11:23 AM |
