Issue With Starting
Old January 11th, 2008, 04:14 PM   #1
JustinSane is on a distinguished road
Issue With Starting
About a month and a bit ago my car was having issues starting. Had a squeal as well as it was being hesitant in starting in general. I replaced the starter which fixed the main issue which was the squeal, however, the other issues with starting are still there. Basically what happens randomly is that when I go to start the car, it takes longer than normal to actually ignite or catch. Just sits there and turns over. I checked my oil the other day and I was really low so I though it had something to do with that. After putting in the oil, things looked good, for about a day. So that was more just wishful thinking I guess.
I'm no mechanic or anything, but my guesses would be either that I need to clean out my carb, change out the fuel filter or change out the spark plugs. What do all of you think I should tackle?
Old January 11th, 2008, 04:15 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
load test the battery.
Old January 11th, 2008, 05:02 PM   #3
How would I do that? I'm learning as I go along.
Old January 11th, 2008, 05:09 PM   #4
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
u have to take it in to a professional places like pep boys and autozone do this for free.
Old January 11th, 2008, 05:11 PM   #5
TheUNZippee!'s Avatar
-load test the battery
-load test the alternator
-check the belt for proper tension
-check for proper spark
-run the computer for codes
Originally Posted by My Wife
Old January 11th, 2008, 05:14 PM   #6
Juggalo_X's Avatar
14+@Slow
Old January 11th, 2008, 07:56 PM   #7
For the hell of it I put in a new battery and it did the same thing. I'll have someone look at it.
Threads Similar to: Issue With Starting
Starting Issue G.T. Rags V6 Mustangs 14 January 8th, 2008 06:34 PM
here is my issue bigbadwollfff04 Drag 35 July 5th, 2007 09:34 PM
Starter Issue provinggrounds V6 Mustangs 12 June 14th, 2007 03:56 PM
t5 issue 342stroker 5.0 Mustangs 3 June 4th, 2007 09:41 PM
99 GT Not Starting, possible fuel issue Tfreestyle 99-04 7 November 15th, 2006 03:22 PM
