After accident can't hear fuel pump
Old January 11th, 2008, 08:09 PM   #1
mustangsusie is on a distinguished road
I purchased a rebuildable,2000 . Was hit in drivers front fender lightly,air bags deployed. I have removed fender,but would like for it to run before I go much farther. Turns over good, but I can't hear the fuel pump run. I have checked the fuse, the cut off switch in the trunk.All o.k. I was told to pull codes, no codes. Help!!!!!Please!!!!
Old January 11th, 2008, 11:03 PM   #2
¡ʇsnq ɹo uʍop ǝpısdn
fuel pump relay? wiring?
kinkage in the fuel pump?
in all honesty the only time when i hear my fuel pump is when everything is quite and i turn the car to the on position but not start
Old January 11th, 2008, 11:05 PM   #3
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
check the relay for it yet?
TT Build in progress.......
Old January 11th, 2008, 11:10 PM   #4
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
does the car run or will it turn over and die?
NCMM #9
Old January 12th, 2008, 01:17 AM   #5
Red face
Car doesn't fire at all. I don't know where the relay is to check it. Where can I buy a good repair manuel for mustangs? Thanks
Old January 12th, 2008, 02:00 AM   #6
ebay... haynes or chilton ... im partial to chiltons they have never let me down
Old January 12th, 2008, 02:02 AM   #7
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
On foxes they are under the drivers seat.... I'm not sure if they still are. If not check the fuse box under the hood.
Old January 12th, 2008, 07:02 AM   #8
stephen has a spectacular aura aboutstephen has a spectacular aura about
You can get the factory shop manual from Helm publications. It's more expensive but much more detailed. You do have to get all three volumes. The sort of thing you are trying to diagnose is in the emmisions manual I believe.
Old January 12th, 2008, 07:19 AM   #9
I found an internet article on this. There is a fuel pump relay, inertia switch, and a fuel pump driver. The driver is regulated by the fuel rail pressure sensor and in effect varies the voltage to the fuel pump to control the pressure. The fuel pump driver is located in the trunk and that would be the place to test for voltage from the relay. I don't know where the relay is. Perhaps in the fuse box in the engine compartment.
I should mention that a malfunction in the PATS system or with the car alarm can induce a deliberate malfunction that prevents starting.
Note my post on "fuel pump problem?"
Old January 12th, 2008, 07:23 AM   #10
The fuel pump makes a humming sound for a few seconds when the ignition switch is turned to the run position. A more definitive test is to measure the fuel pressure with a gauge. It is supposed to be around 40-50 psi.
Old January 12th, 2008, 10:14 AM   #11
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
fuel pump
check the shut off swith in the trunk, its a red button by the drivers tailight i beleive, if you trunk still has all the carpeting and upholstry then youll need to take it out, if the buttons up just push it down, push it down to make sure anyway,
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Old January 12th, 2008, 10:14 AM   #12
99 cobra
N/A
shut off switch
thats what the switch is made to do, if you get into a accident its made to stop feeding the engine fuel to cut the risk of fire
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
SCT MAF
Tune
03 cobra pumps
HVGC
Old January 12th, 2008, 02:46 PM   #13
I checked the fuel cutoff switch in the trunk,o.k. If it is the PATS system, what do I do? Where is the valve on the fuel rail I can check to see if it has fuel that far? Thanks Everyone.
Old January 12th, 2008, 02:49 PM   #14
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
if its a new edge there is a valve on the fuel rail behind the alternator. but ifu cant hear the pump ur not going to have any fuel there. i have a feeling its the inertia switch in the trunk. go check it again. and if its the pats system your theft light would be flashing like crazy.
Old January 12th, 2008, 04:54 PM   #15
I checked the inertia switch again,its o.k.. Checked the valve on fuel rail no fuel.
Old January 12th, 2008, 07:13 PM   #16
are there any leaks under the car or anything??
Old January 12th, 2008, 09:22 PM   #17
No leaks under car,I still don't hear the fuel pump run when I turn the key on. Thanks everybody!!!!!!!!!!!!!!!
Old January 12th, 2008, 09:27 PM   #18
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
maybe the fuel pump went bad..
Old January 13th, 2008, 07:52 PM   #19
Today I checked spark,good spark, The car was running when it was hit, Help !!!!!!!!!!!!!!!
Threads Similar to: After accident can't hear fuel pump
Fuel Pump? lugthug713 94-95 1 July 31st, 2007 11:38 AM
new fuel pump beheivjer Modular Mustangs 5 May 21st, 2007 09:33 AM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
Fuel pump wlbrooks2 94-95 4 April 8th, 2007 01:39 PM
Fuel pump Mustang Mike 99-04 1 February 24th, 2007 03:26 AM
