1998 mustang 3.8l v6
idling
hey i seem to be having trouble with it idling. it seems as if it has a real bad tune or something. it is idling unevenly and sounds awful. and it only does this when it is in gear. not when in P or N. and when i put it in gear and let off the brake it jerks as the rpms go up and down. and when i slightly get on it it jerks horribly. anyone know of anyone having this prob or ever had this prob?
please help
![]() RACING because baseball,basketball, bowling,football, and golf only require one ball |
#2 | |
are you getting any codes or are you tuned?
maybe you have a dirty maf sensor as i did check on that cause my car sometimes didnt wanted to start or idling would go as low as 500 or sometimes it would revved itself. All i did was clean the sensors also removed the battery to reset everything and tada running like new again
oh never thought bout a dirty maf. will def check. not sure on codes. i have an obd2 tester but i just realized it tonight and no time to check it. will check tomorrow. thats how mine is. it goes real low and then revs up and jerks the car. quite embarrassing. and will also try the battery thing. thanks
clean the MAF and IAC
sounds like maf or iac as stated above, also try checking ur tps sensor if its not reading right it will try to adjust itself....
stock 04 blue mach 1 |
Threads Similar to: idling
| Idling Weird... | 97GT4.6 | 96-98 | 12 | November 10th, 2007 01:21 PM |
| Idling problem | dothedew1654 | 94-95 | 9 | November 3rd, 2007 05:01 PM |
| idling problem | 02MiNeRaLgRaYGT | 99-04 | 6 | October 19th, 2007 06:29 PM |
| idling | afmustanglover | General Tech | 7 | April 4th, 2007 10:39 AM |
| My 86 idling | 5literJeff | Videos | 1 | January 18th, 2007 05:26 PM |
