02 sensor problems
Old January 14th, 2008, 09:49 AM   #1
2003 Mustang
street591 is on a distinguished road
Send a message via AIM to street591
02 sensor problems
i got 02 sensor extension for my longtubes and the original sensors fit into the extension but the extension does not fit into the original harness becuase of the clips that help line up the prongs. should i just file off those clips and still have the one main clip work? and the wires look backwards on the bottom (gray and black). will they work fine? also i have a gt x pipe but the sensor holes look like they are too far back. with the MIL eliminators will these still fit or will a need a new sensor with a longer cord? PLEASE HELP
Old January 14th, 2008, 09:51 AM   #2
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
Alot of people have had the same problem. As long as the color wires stay the same....then just cut or file off the clips, and then secure the connection with electrical tape.
Old January 14th, 2008, 09:56 AM   #3
2003 Mustang
well the sockets are still green but where it plugs into the harness it is black and they wires (black and grey) look flipped but do they do that anyway? and any info on the MIL eliminators?
Old January 14th, 2008, 10:01 AM   #4
shadow5403's Avatar
the wires on one side should be a different color than the other. just match up the colors. i think mine were black/gray on one side and green/purple on the other
Old January 14th, 2008, 10:02 AM   #5
2003 Mustang
so they should work then and do know if they original sensors will reack with the MIL even on the gt mid pipe
Old January 14th, 2008, 10:15 AM   #6
shadow5403's Avatar
yes and yes. I remember when i put on my h-pipe i had to shave on the stupid clips to make em work.
Old January 14th, 2008, 10:47 AM   #7
2003 Mustang
but as in length because the V6 driver side is far away from the back hole for the sensor. the MIL and original rear sensor will reach on a gt mid pipe
Threads Similar to: 02 sensor problems
need sensor help mikethetigerrr 99-04 9 September 6th, 2007 04:29 PM
where is my iat sensor? fordmust02 Audio/Video 6 July 6th, 2007 02:36 PM
O2 sensor fitment problems throwedoff 99-04 7 May 9th, 2007 07:21 PM
4 cyl maf sensor or 8 cyl? Darrellx14 5.0 Mustangs 12 January 11th, 2007 10:15 AM
idle and Map sensor problems like WHOAH MIGHTYJO3YOUNG 5.0 Mustangs 1 January 9th, 2007 02:13 PM
