2001 3.8 V6 Mustang Will Not Start * Need Help Bad *
OK been working on this for days. my card died a few days ago when driving. got it home and it would not start, kind of sounds like it wants to but does not. there are new wires and plugs on the car, and have been for sometime. i checked all the fuses and they all tested good. checked the fuel pump and i am getting fuel. i checked for coil pack and found a little problem. the coil pack on my v6 has 3 across the top and 3 across the bottom.
Example: O O O O O O O(have spark) O(have spark) O(NO SPARK) O(have spark) O(have spark) O(NO SPARK) went and got a new coil pack, and the same thing .Any one have any ideas, i have no clue anymore. i thought it was the coil pack.
#2 | |
+1 test your coil with a ohm meter. but i wouldn't even bother replace the coil and be done. its bad.
check your computer maybe too...my car was all jacked up and it turned out to be my computer...prob not that problem but just a precaution
i replace the coil pack with a new one but it is doing the same as the old. the last two. one on top and one on bottom, does not get any spark. to the plug, the wires have been tested and moved to one of the ones the other plugs, but still the same problem, so i thought ok, lets also move the plug over. well the wire and plug work when i swapped them out with the other, but still have the same issue. the last two on the coil pack don't fire.
have your computer check mane.....maybe its shorted and not sending anything to the coils? idk...like i said my computer messed up my car had major missfiring....told my #6 injector to stay open...im dumb but trying to help
#7 | |
Perhaps the computer is bad and putting out pulses to two out of three coils. I don't know how to test that or how much a new one costs. It might be worth having someone look at it with the right test equipment. |
test your Coil harness. it has one VCC and 3 ground. each pair of secondaries have there own ground wire. sounds like it has a open ground for a pair of your secondaries. ill see if i can get yah the wire to test for the secondaries that are dead.
Pink/White i beleive is the ground for the secondaries on your coil that are not firing.
thanks, did find some wiring stuff, for the plugs and coil pack. and see the pnk/wht so when i get home i will test out that wire. so your saying the 3 out 4 wires that are in the harness are grounds, and only one is the hot?
[IMG]file:///C:/DOCUME%7E1/JEFF%7E1.DAM/LOCALS%7E1/Temp/moz-screenshot-5.jpg[/IMG] [IMG]file:///C:/DOCUME%7E1/JEFF%7E1.DAM/LOCALS%7E1/Temp/moz-screenshot-6.jpg[/IMG] |
ok no Pink/White, i forgot what colors they are but will list them wed, but guessing they go from the coil pack right to the pcm, does a pcm go out that easy, and is there any others signs that a pcm is going bad? or any other ideas why there is no spark to the last two on the coil pack. is there a way to test the leads from the clip that goes to the coil pack to the pcm, other them ohm out the line. is there a volt reading ?
Wondered if you had any luck? I had a perhaps similar problem with no spark on some wires and replaced the coil, wires, and crank angle sensor. This did fix it, but it was necessary to crank the engine for some time to get it started again. Perhaps it was flooded after the ignition problem.
have you tried to replace the coil pack?
MM's Resident Ricer
2006 Scion tC
13.001@113
1-4
2-5 3-6 if any two of those have no spark together it is your coil
MM's Resident Ricer
2006 Scion tC
13.001@113
well parallel plugs are on the same coil the chances of it not being ethe coil are real slim
#18 | |
Good idea for testing the inputs. Sort of like using a noid light to check injector inputs. |
#19 | |
Test the Harness like i instructed with a test light this will tell your if you have an open ground. |
MM's Resident Ricer
2006 Scion tC
13.001@113
did he replace the right coil? also coils can be bad out of the box
Threads Similar to: 2001 3.8 V6 Mustang Will Not Start * Need Help Bad *
| 2001 Mustang GT | OcOnnor220 | 99-04 | 18 | December 17th, 2007 12:20 AM |
| 351-W in 2001 Mustang | GreenLxStang21 | Modular Mustangs | 5 | November 4th, 2007 03:05 PM |
| 2001 mustang 5 speed vs. 2005 mustang auto. | DannyStu | Drag | 20 | October 6th, 2007 10:55 AM |
| 2001 GT engine stall after start | jmcconne | 99-04 | 9 | September 8th, 2006 02:08 PM |
