Discussing shift kits in the V6 Mustangs Forum. Originally Posted by Darrin That depends on what you want to do. On several cars ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 | |
MM Ninja / Site Moderator
2001 Mustang 232/CBR600
14+@Slow
no questions. thats why alot of pros use an auto tranny in drag apps.
![]() Modded Autos Join today, All makes all models ̿̿ ̿ ̿̿'̿'\̵͇̿̿\=(•̪●)=/̵͇̿̿/'̿'̿ ̿̿ |
#22 |
14+@Slow
J-Mod by ford is the only other i would use but id prefer b&m. they are the same thing different company.
#23 |
98 Mustang GT
12.85
b&m actually doesn't do anywhere near the same thing as the j-mod.
The link that you provided above has a great price for the valve body, but I had someone buy one from him and took it apart. I was not pleased with it because the valve body was simply sprayed down and not fully disassembled and cleaned or inspected. The one I got back had a broken 3-4 capacity spring in it and the valves were all dirty. His plates are simply overpriced in my opinion. I offer complete valve bodies and plates, but my valve bodies are much higher priced and all I can say is that I do all of what needs to be done and you definitely get what you pay for ![]() My plate kits are higher priced, but you get the plate, gaskets, accumulator springs (accumulator pistons also on older than 98 setups only), and a new filter. I also include some really nice instructions. Torque converters are definitely available as well, just ask. This is what I do. Darrin |
#24 |
2000 V6 Mustang
this BM kit says it only works up until 99.....?
http://store.summitracing.com/partde...15&autoview=sk should still work in a 2000 right? |
#25 | |
14+@Slow
#26 |
2000 V6 Mustang
it is designed for the 4R70W...just didnt know why it said it was up to 99 model year. What torque converter would be good to use?
#27 |
98 Mustang GT
12.85
I think the reason that they say for up to 99 is simply because of the lack of proper info out there on these transmissions. Like said above, if it is for the 4R70W then you can use it.
I am calling them now to have the install instructions faxed to me to see if I can tell you if they changed the kit or not since I looked at it several years ago. Back then it was very similar to the TransGo kit that I REALLY don't like. Darrin |
#28 |
98 Mustang GT
12.85
#29 |
2000 V6 Mustang
can somone link a torque converter for a 2000 4R70W tranny. what stall also?
#30 |
98 Mustang GT
12.85
That is a link to the proper torque converter for that transmission.
On your car you don't honestly need a ton of stall. Stock stall on your application is spec'd between about 2250 and 2600 rpm. For a nice street setup something in the low 3000 range should be good. Darrin |
#31 |
2000 V6 Mustang
i was figurin around 2400? that sound about right?
#32 |
98 Mustang GT
12.85
You won't get into as much trouble with that B&M shift kit as you can with a few others.
I really don't like the fact that they block off the 1-2 accumulator though. That can make for some abusive part throttle shifts and isn't the right way to do it in my opinion. Also, they have you replace the main pressure regulator valve spring. I would really love to see what the difference is on that spring to see if they used the one from the Sonnax kit for that valve. If so then thats a good mod and it would have been nice to see them include the Sonnax valve with the spring. At least they don't have you drilling into the valve body itself on this kit or blocking off stuff elsewhere like with some others out there... Darrin |
#33 |
98 Mustang GT
12.85
According to Ford, 2400 is right about stock stall for your car. I just went out and warmed up one of those cars here to check it and it seems to stall somewhere in the 2500rpm range. That car has a very mild tune on it and it otherwise stock. Well, until I get to it that is. LOL
Are you after a simple stock type replacement converter or a performance converter? Darrin |
#34 |
2000 V6 Mustang
street/strip performance
#35 |
98 Mustang GT
12.85
You definitely want higher than 2400 then or you won't notice a lick of performance improvement out of it. It would really suck to spend all that money and end up with no gain from it other than durability. That is why I was suggesting something in the low 3000 range. That should be enough to notice and get you up and off the line with a little oomph.
Darrin |
#36 |
2000 V6 Mustang
i know nothing of this topic so it may sound stupid but, if i went with a 3000 stall, how would the car perform just boppin around town as if compared to the stock converter?
#37 |
2006 Scion tC
13.9@103/8.9@81
transgo is crap period, as for a shift kit, I had a transgo it sucked horribly so I moved to a b&M kit partnered with a tuner and I loved it, j-mod is a good kit as well, also as for a torque convter on a street strip car with bolt ons your not going to wanna go over a 2500 stall (stock stall for us is 2150 and with a stock converter you wont be able to hold rpms past 2200)3000 and your going to bog like mad off of the line in a v6. best shift kit setup IMO that I have used and will vouche for is a b&m (or j-mod is good i personally didnt own one but I have driven cars with it IMO too choppy for a DD car)) shiftkit, 2500 rpm stall converter and a tuner
![]() Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS MM 4 Banger club: Senior Ricer Members against Mods Crew member #3 "Horsepower sells cars, torque wins races." -Carroll Shelby Last edited by GreenFaleen : January 14th, 2008 at 03:15 PM. |
#38 |
2000 V6 Mustang
i started a new thread in the drivetrain section dealing with this. I already have a tuner, and plan on puttin a tranny fluid cooler on it too. Would i need anything else besides the shift kit and the torque converter?
#39 | |
98 Mustang GT
12.85
![]() Also, a properly j-modded transmission is the absolute smoothest of the modified transmissions at low to part throttle that you can get and they bang with the best at wide open throttle. The key words there are properly j-modded. That said, I have to propose that if you have never driven one done properly and you are nearby and want to experience that then I definitely would love to invite you over to drive some cars. There is a lot of bad info out there abotu this stuff and it woudl be great if we could all work together to start and turn that around so that we can provide the right kind of help to those that want it. Darrin |
#40 |
98 Mustang GT
12.85
Sorry about the size of that pic. I tried to resize it and it only made it blurry???
Darrin |
Threads Similar to: shift kits
| help on shift kits | 1 SNAKE 3 | Drivetrain | 4 | November 9th, 2007 12:49 PM |
| Shift Kits? | poisonstallion95gt | 5.0 Mustangs | 9 | October 3rd, 2007 05:09 AM |
| Shift kits for an auto | mrnewall | 99-04 | 1 | May 7th, 2007 09:43 AM |
| Shift Kits | 95wip | 94-95 | 6 | April 27th, 2007 12:09 PM |
| AOD Shift Kits | man_of_war2081 | 99-04 | 8 | September 29th, 2006 09:36 PM |
