shift kits
Old January 14th, 2008, 11:30 AM   #1
riddlee josh's Avatar
1998 mustang 3.8l v6
riddlee josh is on a distinguished road
shift kits
hey im lookin into getting a shift kit. will this one fit. Ford Racing Shift Kits - JEGS
if not are there any from jegs that will fit?
i have a 1998 auto mustang
thanks
RACING
because baseball,basketball,
bowling,football, and golf only
require one ball
Old January 14th, 2008, 11:32 AM   #2
98 Mustang GT
12.85
Darrin is on a distinguished road
Nope, you have a 4R70W transmission. That stuff there won't work.
I can help you with that by the way. You can give me a call if you want at 317-514-0816 and I can fill you in on what is available for your car.
Darrin
Old January 14th, 2008, 11:35 AM   #3
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
It will
but i wouldnt buy that one
id atleast get a transgo high perfomance kit
1996 Cobra
To be sold...
2005 M6 Twin Turbo GTO Torrid Red
Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps.
Old January 14th, 2008, 11:37 AM   #4
Hourofpain's Avatar
Darrin
no he doesent
the 99+ came with the Fully electronic automatic overdrive transmission dubbed the 4R70W
Everything before had a standard automatic
Hence Why you need to change a gear in the tranny to effect the speedo
1996 Cobra
To be sold...
Old January 14th, 2008, 11:38 AM   #5
well i need to get one at jegs. i have a gift card and no cash and lucky for me jegs don't have much for a sixer
what about this one? B&M 40266 - B&M Shift Improver Kit - JEGS
RACING
require one ball
Old January 14th, 2008, 11:45 AM   #6
98 Mustang GT
12.85
Originally Posted by Hourofpain View Post
no he doesent
I say this with all due respect, but you need to do a little more homework. The 96 and newer Mustangs came with the 4R70W transmission. I kind of do this work professionally. LOL
Darrin
Old January 14th, 2008, 11:46 AM   #7
98 Mustang GT
12.85
That one would work. Not my favorite, but it will do.
Darrin
Old January 14th, 2008, 11:46 AM   #8
Hourofpain's Avatar
ID buy the ford racing one before i ever bought a B&m shift improver kit
1996 Cobra
To be sold...
Old January 14th, 2008, 11:50 AM   #9
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
id buy B&M
Old January 14th, 2008, 11:53 AM   #10
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
Id also buy B&M, they make very good products.
Old January 14th, 2008, 11:53 AM   #11
98 Mustang GT
12.85
LOL...
I would buy neither. But I am obviously biased and say that from knowing how these kits do what they do.
To me it all comes down to makling the transmission work better in a way that will actually make it last longer, not just making it bang as hard as possible on every shift at all throttle positions. That hurts the transmission and driveline components.
Darrin
Old January 14th, 2008, 11:55 AM   #12
shadow5403's Avatar
LOL...
Darrin
You referred to yourself as someone who does this for a living? I was told by my uncle who works on transmissions that you can get the same effect with a tuner as if you used a shift kit....good or bad info?
Old January 14th, 2008, 11:59 AM   #13
Juggalo_X's Avatar
14+@Slow
LOL...
To me it all comes down to making the transmission work better in a way that will actually make it last longer, not just making it bang as hard as possible on every shift at all throttle positions. That hurts the transmission and drive line components.
Darrin
a shift kit is designed to increase valve body pressure, which in turn speeds up the automatic clutch. = longer automatic clutch life. and added valve body life.
Also a tuner can have the same effect. but a shift kit is better for the benefit of a longer living tranny with the same results as a tuner. for the 99+ stangs.
PS> provided your tanny, drive line and suspension are in good working order and undamaged. it wont case a problem. there are HUNDREDS of guys on here with shift kits. working fine still.
Old January 14th, 2008, 12:00 PM   #14
Juggalo_X's Avatar
14+@Slow
this is true you can get the same effect from a tuner on 99+ stangs.
Old January 14th, 2008, 12:00 PM   #15
shadow5403's Avatar
id rather blow the tranny up and swap in a manual
Old January 14th, 2008, 12:01 PM   #16
98 Mustang GT
12.85
Yeah, this is what I do. Actually you can see some of my work in the January Muscle Mustangs and Fast Fords on page 168 where HP Performance used my stuff to swap a 4R transmission into a Cobra.
To directly answer your question, you can't get exactly the same thing with a tuner. Honestly, a tuner can hurt things since it jacks up the line pressure instead of adressing the actual fluid flow. This can hurt the transmission. Kind of the same thing that several of the 'shift kits' on the market do as well.
You can get harder shifts with that stuff, but there are much better ways. The tuner by itself is not the best for sure.
Darrin
Old January 14th, 2008, 12:06 PM   #17
Juggalo_X's Avatar
14+@Slow
"The J-Mod shift modifications were designed by a Ford transmission engineer, these modifications allow for faster shifting and extended transmission life."
Source, one of MANY
nuff said
B&M and J-mod (Ford) are both fine choices that will extend tranny life. id go with B&M tho. we know the quality of ford parts can some times be less then great
Old January 14th, 2008, 12:07 PM   #18
98 Mustang GT
12.85
That depends on what you want to do. On several cars we have made them considerably quicker with the right automatic setup. More than one of them went a full second quicker than it did with it's old manual setup. Muscle Mustangs covered the swap we did into a Bullitt where that car literally skipped over the 10's. He had run consistantly in the 11.0x second range and after the auto swap and getting the tune down right he was putting out consistant 10.0x runs. The same guy tuned it with both the auto and manual setups and really the only changes in the tune were to account for the automatic stuff. Did have to change computers though since the manual computers won't run a full auto setup unfortunately.
Darrin
Old January 14th, 2008, 12:07 PM   #19
Juggalo_X's Avatar
14+@Slow
i just wanna add that if your drive your stang in the snow... a tuner is a better option because ur not going to want to have solid shifts in low traction situations. or your going to get some wheel spin and fish tailing.
Old January 14th, 2008, 12:08 PM   #20
shadow5403's Avatar
what is a good company aside from B&M to get a shift kit for a 2000 mustang 4R70W. and a torque converter?
Threads Similar to: shift kits
help on shift kits 1 SNAKE 3 5.0 Mustangs 4 November 9th, 2007 11:49 AM
Shift Kits? poisonstallion95gt 5.0 Mustangs 9 October 3rd, 2007 04:09 AM
Shift kits for an auto mrnewall 99-04 1 May 7th, 2007 08:43 AM
Shift Kits 95wip 94-95 6 April 27th, 2007 11:09 AM
AOD Shift Kits man_of_war2081 99-04 8 September 29th, 2006 08:36 PM
