02 problems
Old January 14th, 2008, 04:09 PM   #1
2003 Mustang
street591 is on a distinguished road
Send a message via AIM to street591
02 problems
I put longtubes on and the 02 sensor extensions didnt fit the harness so i cut the tabs off and they now fit. I have a gt mid pipe so the sensor holes are back farther. The original sensors and MIL will not reack all the way back if i get two more extensions will they work on the back too?
Old January 14th, 2008, 04:10 PM   #2
2003 Mustang
Old January 14th, 2008, 04:11 PM   #3
¡ʇsnq ɹo uʍop ǝpısdn
since they are being MIL'd out... all you need to do is make sure that the sensors are connected other then that they don't need to be in the holes if they don't fit... you might be able to stretch the existing plugs to make it work
Old January 14th, 2008, 04:11 PM   #4
Originally Posted by street591 View Post
patience is a virtue... i can only type so fast
Old January 14th, 2008, 04:38 PM   #5
2003 Mustang
so if i put the extensions on the front ones with the clips cutoff that will work and if i put the MIL eliminators in and cut the clips off the passenger sensor so it fits into the MIL then cap the holes everything will work? the car and carbeurator will be fine?
Old January 14th, 2008, 04:44 PM   #6
carbeurator??
shot what year is your car? and if you car has a carbeurator then fat chance it has O2 sensors... they didn't really start to use the O2 sensors until fuel injection came out
cuting the tabs off is a must for some cars... the sensors will be fine
capping the rears will be fine did that on my car and it works just fine... with the mils that i have
Old January 14th, 2008, 04:46 PM   #7
2003 Mustang
its an 03 V6 and where did you get your MIL? is yours a V6 also?
Old January 14th, 2008, 04:50 PM   #8
yes
i have the splice in kind... they are two wire splice ins
V6mustangstuff.com ... i got them from a great friend who bought them the didn't end up needing them
your car is fuel injected... they haven't used a stand alone carb system since... late 70s early 80s
Old January 14th, 2008, 04:52 PM   #9
2003 Mustang
so then its ok to cap them off cause it isnt a stand alone carb its fuel injected
Old January 14th, 2008, 04:54 PM   #10
carburetors didn't have O2 sensors... they didn't have a computer that needed that information
the reason its okay to cap them off is because the MIL's are sending fake signals to the computer telling it that the catalytic converters are working like they are suppose to be
Old January 14th, 2008, 04:58 PM   #11
2003 Mustang
so it'll run the same with them capped off? and i think they got rid of theose MIL i cant find them lol
Old January 14th, 2008, 04:59 PM   #12
you have to contact them to place an order for them from what i know
Old January 14th, 2008, 05:02 PM   #13
2003 Mustang
but any MIL eliminators will work right? and how do i leave you some rep
Old January 14th, 2008, 05:04 PM   #14
yes any of them will work, except one wire eliminators... those are not designed for our cars... you either need the plug in connector ones for about $60 or the splice em up ones for i think like $15
click the scale under my name next to the caution sign
Old January 14th, 2008, 05:06 PM   #15
2003 Mustang
ok cool and the reason this works so i learn is cause the carbeurator doesnt have any 02 sensors connected to it it just runs off the computer and the computer doesnt change cause of the MIL right?
Old January 14th, 2008, 05:09 PM   #16
your car doesn't have a carburater... they don't do those any more...
MIL sends a fake signal saying that everything is working right
and back in the day... nothing to do with your car... they didn't use O2 sensors cause the technology didn't exist / wasn't cheap enough to put on a car
Old January 14th, 2008, 05:10 PM   #17
2003 Mustang
ok thanks onemanzu cya
Old January 14th, 2008, 05:13 PM   #18
no prob
Threads Similar to: 02 problems
A/C problems throwedoff 99-04 3 September 25th, 2007 07:42 PM
a few problems. 1BADSTANG 5.0 Mustangs 6 September 17th, 2007 10:37 PM
problems plz help cams-shelbycobra07 2005 - 2010 6 June 13th, 2007 11:27 PM
Car Problems bigbadtalontsi 5.0 Mustangs 4 January 15th, 2007 08:52 PM
88 GT With A Few Problems Iceman1989 General Tech 3 November 14th, 2006 12:58 AM
