Discussing fuel pump relay in the V6 Mustangs Forum. jesus christ look at ll this is information. the fuel pump relay is part of ...
Old January 17th, 2008, 04:41 AM   #21
juan310's Avatar
jesus christ look at ll this is information. the fuel pump relay is part of ccrm(constant control relay module) which houses other relays as well. it is located on the passenger side behind the splash guard. you would have to replace the entire ccrm unit. if your fuel pump keeps going out i would also check your fuel pressure sensor and your fpdm(fuel pump driver module) which is near the inertia switch(the thing with the red button) in your trunk. and also what pump are you using as a replacement?
Old January 17th, 2008, 01:13 PM   #22
Take a look at the following. It has quite a bit of detail about how the system works.
Fuel Pump Speed Controls Add to Diagnostic Complexity
Threads Similar to: fuel pump relay
Fuel Pump Still Not Getting Power At Relay Illuminator 5.0 Mustangs 11 December 29th, 2007 02:38 AM
Fuel Pump Relay hopper 5.0 Mustangs 22 December 21st, 2007 11:41 AM
Where Is The Fuel Pump Relay? blownsnake96 5.0 Mustangs 4 December 11th, 2007 02:12 PM
HELP!!! Where is the Fuel Pump Relay?? REBELPONY 5.0 Mustangs 2 August 5th, 2007 02:16 PM
Fuel pump relay crazyfast50stang 5.0 Mustangs 4 August 30th, 2006 10:49 PM
