1998 mustang 3.8l v6
misfire
hey remember i told you guys my car was idleing bad? well i tested it today with my obd2 tester and it read that it has random multiple misfires. i kinda know what this means but how do i fix it and what caused it?
![]() RACING because baseball,basketball, bowling,football, and golf only require one ball |
please reply
Check plugs wires and coil pack.
Also check your freeze frame data and see if it specifies what CYL misfired last. start with that one and take a look at the wire and plug.
what is freeze frame data? and how do i get it?
any help at all?
Most OBD2 tools support a freeze frame. unless its a cracker jack box scan tool. mine i can scan and then interface with my pc and it tells me when all the codes took place, engine temp, rpm speed all the good stuff.
well mines cheap so i guess i can't check that. im thinking that i need to get new wires and plugs for it. but i don't know that it would help any
check your computer...mine fried to where it was telling my number 6 injector to constantly stay open so i was missfiring bad..just throwin that out there
um ok. how do i go about checking it?
i took mine to a mechanic..thats all i could do..the whole time i thought i had a bad wire or injector..thats what everyone on here thought too and idk how they go about checkin the computer..
oh well im def going to try and hope that mine is a wire but if all else fails i will def go have that checked. and did you have to get a whole new computer? and how much did it cost?
yea i had to get a new computer...but..i have OBD1 so it was kinda hard to find one....all and all i paid like 300 bucks for a new computer and labor..
will it hurt the car to drive it this way?
my f150 was misfiring last summer and i had a tune-up performed. it runs fine now. you may have to do the same
2005 Ford F150 FX4-New Toy MM Truck Crew ![]() 2002 Ford Mustang V6-Sold ![]() 1997 Ford Mustang V6-Sold |
#17 | |
mechanic played you i doubt you computer was bad let alone FRIED you'd know if your computer was friend it wouldnt run not just say oh your #6 injector is open...thats just a bad injector easy like $30-50 40minute job most likely if your having RANDOM missfires in each cylinder your coil is bad check your wires with a spark tester that you can buy at any auto store
#18 | |
i bet you have 1 new or used injector depending how much of a dick the mechanic is and thats it
#19 | |
honestky idc aslong as my car got fixed...had a trip to go on in two days so i said whatever...we cleared it with a scanner and it was fine momentarally then acted up again..
Threads Similar to: misfire
| cylinder #8 misfire | tallman20 | General Tech | 4 | October 14th, 2007 04:11 PM |
| misfire at high rpm | musclemike | 5.0 Mustangs | 2 | September 12th, 2007 02:23 PM |
| Misfire BAD | Casper98GT | Modular Mustangs | 4 | September 5th, 2006 07:24 PM |
| 02 4.6 misfire...help me | aaron175617 | 99-04 | 5 | July 14th, 2006 09:25 PM |
| misfire.... | stang fanatic | General Tech | 10 | June 23rd, 2006 10:08 AM |
