Rear End Replacment
Old September 14th, 2006, 10:12 PM   #1
97stanger is an unknown quantity at this point
Rear End Replacment
Hi there! I have a 1997 mustang v6 (3.8) and I need a new rear end from rotor to rotor. Could I just pull a complete rear out of a 95-98 GT model and put it on? will my acceleration be faster, or my top end? will it do anything to the engine? I know it tuned to run with the v6 model ( the rpm's are). Will it do anything to the motor? I know I will lose about 1 -2 mpg. But is it possible? I believe that the v6 rear is 7.5 in lenght??? And I believe that the GT is 8.8 in length. Will it fit in there? Please advise. thanks!!!
Old September 14th, 2006, 10:50 PM   #2
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
you can and the 8.8" rear bolts right in from those years and gives you added durability and the tlok differential. you will have the same gear ratio as a stock v6 at 3.27:1 and will lose no mpg at all and not require a tune. the only difference is the stronger, bigger rear end and axles and tlok differential to lock both rear tires.
ModdedAutos
1999 Mustang V6
Old September 14th, 2006, 11:15 PM   #3
I thought that the v8 and the v6's had different ratios? What rear would you reccomend? I drive my mustang a hell of a lot harder than I should. I push this car. would the v8 rear do just fine? Or should I put a Cobra rear on it?What is the earliest and latest year rear that will bolt right up? Does the v6 rear have tlok? Lastly, will I need to get a new speedo? or will the speed still register the same?
Originally Posted by BWAL09
aww, you fucking piece of shit, you are making me get all fucking emotional now
Old September 14th, 2006, 11:19 PM   #4
I am completely stock right now. I have no idea what my horsepower is??? Do you know? I wanna have my 0-60 time right around 6 seconds. I know its not there now. What do I need to buy in order to achieve that?
I know right now on highway races I blow Neons, Civics, Accords, Eclipse, Prelude's, and I actually beat a Scion TC.
What do I need to get in order get my 0-60 around 6 seconds???
Thanks!
Old September 14th, 2006, 11:20 PM   #5
14.79 @ 92.15
v8 can have 3.27 stock, 3.55 in the mach, and some people change them for 3.73, 4.10 or 4.30 often...
i recommend an 8.8 out of the same year car you have. you wont break the 8.8 unless you have a 5 speed dropping from 5k, slicks and over 400 ft/lbs of tq on stock axles.
v6 does not have t lok
years from 96-98 will bolt right up
if it has same gear ratio, you dont need a new speedo, speedcal, or tune
ModdedAutos
1999 Mustang V6
Old September 14th, 2006, 11:20 PM   #6
kerry is on a distinguished road
i know that the speed sensor is in the transmission so i do not belive that it will mess that up at all, but i would also like a new rear for my 94 because it doesnt hook up for crap, can these rear ends be had at junkyards?
Old September 14th, 2006, 11:32 PM   #7
14.79 @ 92.15
if you have a 5speed, the speedo sensor is in the tranny, but the gear ratio is the same so it wont change anything
ModdedAutos
1999 Mustang V6
Old September 15th, 2006, 12:10 AM   #8
Sry. I meant to mention that mine is a 5 speed. I couldnt find one from a 97 mustang. The closest year I Found was 1998 Gt. it is from a junk yard. The Mustang had 46k on it.
What mods do you think I should do to get 0-60 to 6 seconds???
Old September 15th, 2006, 12:12 AM   #9
14.79 @ 92.15
96-98 gt will work
to get a 6second 0-60 you will need sticky tires on a track and more than 4.10s/tlok/bolt ons because i dont have a 6second 0-60
ModdedAutos
1999 Mustang V6
Old September 15th, 2006, 12:14 AM   #10
Yes, they do sell them at junkyards. Prices vary from 100 up to 900.00 Call first to make sure they have a mustang. Most dont keep an inventory of the cars they have. Make sure the mileage is reasonable on the junked car. Some junkyards even offer a 30-60 day warranty on them.
Old September 15th, 2006, 12:16 AM   #11
for 0-60 Im not just talking about the rear. Im talking engine wise. What do you think I should do to the engine.
Sorry, I'm new to this. Just trying to get a few pointers. bear with me please.
Old September 15th, 2006, 12:21 AM   #12
99mustang232's Avatar
99mustang232 is on a distinguished road
you can get a brand new 8.8 rear w/3.73's from FRPP for about $800 that will bolt up, but you will have to correct for the ratio difference
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old September 15th, 2006, 12:21 AM   #13
14.79 @ 92.15
you'll need forced induction. maybe a cam and a strong n/a setup with the right weight and gears can get you a 6 second 0-60, but a 6 second 0-60 is like a low 14 with good traction and a good launch on slicks. you could do that n/a with a perfect tune, but you need about 270rwtq to do it
ModdedAutos
1999 Mustang V6
Old September 15th, 2006, 12:29 AM   #14
What is n/a? I assume, you mean the 4.10 gears?
Old September 15th, 2006, 12:31 AM   #15
14.79 @ 92.15
naturally aspirated. no forced induction. not the gears, sorry for the mix up.
ModdedAutos
1999 Mustang V6
Old September 15th, 2006, 12:33 AM   #16
thanks for being paitent. I'm new to this. It's my first Mustang, and i want to do it right.
Old September 15th, 2006, 12:36 AM   #17
14.79 @ 92.15
cool. you will want to get the 8.8" rear if you want to do it right as opposed to building the 7.5. i only built my 7.5 because it is a little cheaper and i dont plan on making the power necessary to break it with an auto tranny. but if you have 350rwhp and launch with sticky tires on a 5 speed, you will snap an axle on the 7.5.
ModdedAutos
1999 Mustang V6
Old September 15th, 2006, 12:36 AM   #18
I went to the website you gave me and I found a cam. Could you tell me what choosing a "B" cam means? this is what it says:
If choosing a "B" or higher performance camshaft...you'll also need to change your stock valve springs to heavier springs, to prevent coil binding.
Do i need new valve springs? Should I get them just incase?
Old September 15th, 2006, 12:37 AM   #19
14.79 @ 92.15
depends on how fast you spin it. i believe 99mustang232 knows a lot about the cams for our cars and has posted an article somewhere. maybe try PM'ing him to get more info. i barely know the basics of morana's cams
ModdedAutos
1999 Mustang V6
Old September 15th, 2006, 12:39 AM   #20
definatelly. I will Pm him. thank you.
Lastly, What is naturally aspirated induction?
Threads Similar to: Rear End Replacment
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 22 April 25th, 2011 04:59 PM
plastic intake replacment beheivjer Modular Mustangs 0 May 14th, 2007 10:17 AM
8.8 rear yes or no? Stang6899 V6 Mustangs 29 April 17th, 2007 06:50 PM
What rear end? ken5_0 5.0 Mustangs 13 March 20th, 2007 02:01 AM
Rear Rotors and Rear Axle rondaw3g0410 99-04 1 September 6th, 2006 11:00 PM
