Shredded cam gear, what caused it?
Old January 23rd, 2008, 07:25 PM   #1
99v6stang's Avatar
99v6stang is on a distinguished road
Okey so both the outermost gear on my cam, and the cam position senor gear have somewhat shredded themselves and i am wondering how this happened. I attached a picture, but i duno if the attachment will work, and its hard to get a good photo. It looks like most of the damage is on the part of the cam gear towards the cam itself. Also how exactly does this gear drive the oil pump as well?
PICTURE LINK>>>> Putfile - Uploaded Picture
My car ---- (m112 in progress)
Old January 23rd, 2008, 07:30 PM   #2
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
i cant even seee the picture
[SIGPIC][/SIGPIC]
Acmillr loves me
Old January 23rd, 2008, 07:32 PM   #3
99v6stang's Avatar
you cant see it? it shows up for my computer, i just added a link to it.
Old January 23rd, 2008, 07:54 PM   #4
99v6stang's Avatar
here is anoth picture showing both gears, my thoughts are is that either somehow there is some vibration in the cam, or the oil passage holes are not fully drilled?
\Putfile - Uploaded Picture
Old January 23rd, 2008, 08:28 PM   #5
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
hit the flower button on your camera before you take the pic, and by what I can tell your timing is way off get a tune man
NCMM #9
Old January 24th, 2008, 12:52 AM   #6
Blainestang's Avatar
Blainestang is on a distinguished road
Exactly what happened to mine.
Did you ever get a chance to check the oil passage?
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles
2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP)
2001 Harley Davidson F-150
Acts 16:31
Old January 24th, 2008, 09:29 AM   #7
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
turn your flash off..the pic is one giant reflection
Old January 24th, 2008, 12:15 PM   #8
99v6stang's Avatar
no i havent checked the passage yet but i will tonight, i got the heads and everything off i just need to remove the radiator fan so i can pull the cam out. And the timing is not off, it would be possible for the cam position sensor to have been slightly off though. Also the car ran fine for 2 months lets not forget so the the timing couldnt have been off or it wouldnt have lasted this long. I will get better pictures tonight.
Old January 24th, 2008, 01:00 PM   #9
Hmmm... well, mine only ran <15 minutes before it destroyed those gears because the passage was non-existant... so I doubt you have ZERO oil flow through the cam passage, but it could still be smaller than it should be, I guess.
Acts 16:31
Old January 24th, 2008, 01:15 PM   #10
MM's Resident Ricer
2006 Scion tC
13.001@113
well from the pics it looks like just the rear of the gear is destroyed which makes me think either the cam is wobbling or your timing is set funny makeing the cam fall at an uneven duration
NCMM #9
Old January 24th, 2008, 04:04 PM   #11
stephen has a spectacular aura aboutstephen has a spectacular aura about
[QUOTE=99v6stang;806288]Okey so both the outermost gear on my cam, and the cam position senor gear have somewhat shredded themselves and i am wondering how this happened. I attached a picture, but i duno if the attachment will work, and its hard to get a good photo. It looks like most of the damage is on the part of the cam gear towards the cam itself. Also how exactly does this gear drive the oil pump as well?
It drives the oil pump by a shaft that comes out of the crank position sensor.
I don't know what happened to the gears other than insufficient oil for some reason. Could the cam bearings be bad by any chance resulting in low oil pressure to the gear and possible wobbling?
Old January 24th, 2008, 04:40 PM   #12
Yeah, essentially, the CPS gear is on a rod that spins the CPS (at the top of the rod) AND the oil pump (bottom of the rod).
Acts 16:31
Old January 24th, 2008, 08:48 PM   #13
99v6stang's Avatar
okey i got a little better pictures, i decided my camera is crappy.
the oil passages look fine and i can blow through the just fine. I could not wobble the cam at all by hand, and yes the majority of the damage does appear to be on the back side of the gear. I am still very confused as to how this happened. all timing marks line up at tdc. There was no oil in the oil filter after running for about thirty seconds with a new oil filter so is it my oil pump?
Old January 24th, 2008, 09:16 PM   #14
00 V6 & 09 GT
ok if theres a bad bearing or its not seated correctly or lose
then thats really the only cause to it, there should be NO other reason for it to grind up or get chewed at
[SIGPIC][/SIGPIC]
Acmillr loves me
Old January 24th, 2008, 09:17 PM   #15
00 V6 & 09 GT
btw that is one shitty camera bro sorry to tell you but the focus is just Horrible
[SIGPIC][/SIGPIC]
Acmillr loves me
Old January 24th, 2008, 09:30 PM   #16
99v6stang's Avatar
yea the camera is a cheap kodak easy share thing i bought for like eighty bucks with a printer. Anyways, how would i go about checking the bearing or to see if it is seated properly?
Old January 24th, 2008, 09:32 PM   #17
00 V6 & 09 GT
put it back in postition
while its in postition try to shake it or move it side to side. it should not move
[SIGPIC][/SIGPIC]
Acmillr loves me
Old January 24th, 2008, 10:22 PM   #18
99v6stang's Avatar
i did before pulling it out and it did not budge at all. So i dont know what the problem is
Old January 24th, 2008, 10:23 PM   #19
MM's Resident Ricer
2006 Scion tC
13.001@113
how long had the cam been in?
NCMM #9
Old January 25th, 2008, 12:28 PM   #20
99v6stang's Avatar
the cam was in for 3000 miles.
Threads Similar to: Shredded cam gear, what caused it?
Cam gear and camshaft position sensor gear... 99v6stang V6 Mustangs 17 January 17th, 2008 02:00 PM
Does anyone use gear to gear timing? e3sean 5.0 Mustangs 24 December 27th, 2007 02:37 PM
Canned Tune Caused Motor To Die Modern_Muscle 2005 - 2010 7 November 18th, 2007 06:51 PM
Can a ticking noise be caused from an exhaust leak?? ricerraper33 General Tech 7 September 21st, 2007 04:42 PM
4.30 Gear to much gear for street use/daily driver? Bigb2000GT 99-04 10 March 28th, 2007 05:22 PM
