seized engine - Page 2
Old January 28th, 2008, 11:53 AM   #21
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
Originally Posted by stephen View Post
The melted main bearing was #3 which has the thrust surfaces. It actually dropped metal down into the pan, sort of like spilled solder. The bad rod bearing was #3 cylinder. The bearing shells are stuck to the crankshaft. I will see how the machine shop plans to fix that. It would seem if you heated them up they would come off. The crank has a little damage to one thrust surface but the journals are still smooth. At the very least I will get it ground one undersize and they will have to fix the thrust. It would probably also be wise to have them align bore or hone the main bearing saddles and resize the rod big ends. Other than that I plan to put in new rings and all new bearings (including the cam bearings. The front one is showing some copper.). The heads had been rebuilt a year or so ago and should be OK, though I may have them install new stem seals again. I would also like to get new lifters.
Maybe I should just get a new rotating assembly as you suggested.
yessir
Forged 3.8L supercoupe
steel 4.2L
Redlined Performance Mustangs
unless you just want a stock rebuild
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: seized engine
Washed n cleaned engine today.. pics of engine bay. MustanG_guy17 The Clubhouse 40 January 4th, 2008 10:14 PM
Will My LT Headers From My Stock Engine Fit On The Mach 1 Engine? tcasoccer13 96-98 12 December 3rd, 2007 09:13 AM
Possibly Seized motor Kaane 96-98 8 April 30th, 2007 11:35 AM
Will a 2002 Gt Engine Directly Replace a 2000GT engine? Bigb2000GT 99-04 7 April 22nd, 2007 05:09 PM
seized motor 83five0 5.0 Mustangs 9 December 18th, 2006 04:23 PM
