interior neon help
I had asked the ither day about how to remove the bottom part of the console, and i figured that ch out, but i've been trying to wire in some neons for under the seats and dash to light up the inside. I was trying to run it off of a switch which i put where the lighter socket thing used to be. The only problem is, i blew a fuse so i had to stop working, but i can't figure out how to get them to run off of the switch. They'll stay on all the time, but on't work with the switch...
you have to run the power wire to the switch then from the switch to an actual power sourse like a battery or somethingif you run a wire from the neon to a power source then another wire to the switch then yea the switch is worthless
![]() iTrader: 1 reviews
just hook all the neons up to a cigarette lighter. then you can just plug it in whenever you want to.
yea, do you know if the wires that originally ran to the lighter socket thing are from the battery? or what?
MM's official Chevy guy
u could run them to the cig lighter in the box under the arm rest, that way it is a easy hook up and clean.
![]() "Speak softly and carry a big stick" - Theodore Roosevelt "Any idiot can make a V8 fast, it takes a real idiot to make a fast V6". ![]() '02 Mustang N/A 4.3 stroker away for winter '72 Chevelle project car 454 coming '93 Bronco EFI 351W DD |
#7 | |
48.47@ 12.58
think of what the switch is actually for.. it breaks/connects the hot wire (power wire)
yea, i had thought about that, i would just prefer having the switch you know. i mean why get sometihng if it isn't set up the way you want it.
if you hook it up the the cigarette light it'll ALWAYS be on due to the constant flow of power to it. so when the car is off your neons will be on....
yea, i think he meant like those stupid neons with the plugs that go in a lighter thing sort of like a cell phone charger. i don't like them
ya thats what i thought u had my bad,
Wow!, did you whip that up just for me?
but yea, i thought that's ho i went, it's just on my switch, there are two positive wires, and one negative...
#15 | |
btw those wires are BEHIND the inlet for the cigarette lighter so its more hidden
make sure you have the positive from the switch spliced to the main wire, and the negative can just be grounded to any good source of metal or the black wire on the cig lighter
ok, i had the positive connected to the main wire, but the negative i had connected to the negative wire from the neons, and the other positive wire i had connected to the positive wire from the neons.
MM's Resident Ricer
2006 Scion tC
13.001@113
for my interior cathodes i did an add a circuit from advanced tapped into my fuse box for power added the second fuse for the cathodes then did
add a circuit to top post on switch positive from cathodes to bottom post on switch and ground from cathodes to a screw under my dash its easier than running wire from outside the car
Threads Similar to: interior neon help
| Interior Neon Lighting? | D-Brow | Visual | 47 | December 14th, 2007 03:22 PM |
| neon color | trueballerisme | Visual | 31 | September 24th, 2007 10:49 PM |
| Neon? | MustangMo | V6 Mustangs | 58 | May 21st, 2007 09:55 AM |
| neon srt-4 v. 04 GT | jeremy | 99-04 | 48 | March 14th, 2007 02:52 PM |
