Whats it called?
Old January 24th, 2008, 11:03 PM   #1
scxc15's Avatar
2003 Mach 1
12.7@107
scxc15 is on a distinguished road
Whats it called?
Whats the fiberglass piece that sits directly in front of the radiator, Its Holds on the head lights and the very from on the font bumper/grille?
Old January 24th, 2008, 11:15 PM   #2
ROUSHME661's Avatar
ROUSHME661 is on a distinguished road
Send a message via AIM to ROUSHME661 Send a message via Yahoo to ROUSHME661
its called a header panel you can find them on ebay pretty cheap
i crashed and had to replace mine
01 v6
true duals with 40 series flows and custom h pipe
cold air intake
http://www.myspace.com/xxarsonfreakxx (PERSONAL)
Old January 24th, 2008, 11:16 PM   #3
scxc15's Avatar
2003 Mach 1
12.7@107
As did I lol.
I just had no clue what it was called.
Old January 24th, 2008, 11:19 PM   #4
ROUSHME661's Avatar
neither did i..luckly my friends dad owns a wrecking yard so i just went out there and pulled it myself
01 v6
cold air intake
Old January 24th, 2008, 11:24 PM   #5
scxc15's Avatar
2003 Mach 1
12.7@107
There is a mustang junkyard about 30 mins away and I can get a brand new one from them for $50. I found one on ebay for @20, but shipping is $40 so it kinda ruins that lol.
Old January 24th, 2008, 11:39 PM   #6
ROUSHME661's Avatar
well good luck with that man hopefully thats all the damage done to your car
01 v6
cold air intake
Old January 24th, 2008, 11:49 PM   #7
scxc15's Avatar
2003 Mach 1
12.7@107
My radiator support is bent some , but were just going to bend it back instead of replacing it.
Old January 25th, 2008, 12:05 AM   #8
1995 Mustang Coupe 3.8l
STREET6 is on a distinguished road
I have a 95 mustang and have to replace the radiator support. Actualy it was damaged when i bought it. The previous owner had put on a good bumper cover and the part you need so luckily i don't need all those parts. You are lucky you can just bend your core support back because it looks like a pain to cut out and put in a new one and hope that all else is strait. do you have any pics of your bent core support?
Good luck.
1995 Mustang Coupe. 3.8l Auto. Bought for $800 and it shows. Swapping in 5.0l carbed. T5 Tranny. Goal 325HP.
Old January 25th, 2008, 12:09 AM   #9
scxc15's Avatar
2003 Mach 1
12.7@107
I'll post some pics when we fix it. Yea if for some reason we do have to put it a new one it will suck soo bad cause its not bolted on, its welded. First we are taking on the radiator so we don't hurt it. Then we are either 1) going to heat it up and bend it or 2) cut the bottom part of with a plasma cutter and bend it and then weld it back on. Probably the ladder of the two cause it will be easier.
Old January 25th, 2008, 05:19 AM   #10
GtrTech's Avatar
GtrTech will become famous soon enough
You should be able to find one cheaper local
eBay Motors: NEW HEADER PANEL MOUNT 99 00 01 02 03 04 FORD MUSTANG
The war is coming to the streets of America and if you are not keeping and bearing and practicing with your arms then you will be helpless and you will be the victim of evil.
Ted Nugent
Old January 25th, 2008, 08:07 AM   #11
scxc15's Avatar
2003 Mach 1
12.7@107
$50 is pretty cheap considering it's brand new and I don't have to unbolt it from a wrecked car. Like I said $20 on ebay, but $40 in shipping..
Threads Similar to: Whats it called?
what is this part called menian 5.0 Mustangs 4 September 24th, 2007 01:17 AM
Whats that thing called scxc15 V6 Mustangs 26 May 4th, 2007 12:07 AM
what's this engine called? MicronXD V6 Mustangs 5 February 4th, 2007 12:05 PM
What are these called? motoking69 5.0 Mustangs 9 December 7th, 2006 12:14 AM
