Clutch / Engine
Old September 18th, 2006, 02:09 PM   #1
3856Black'00 is on a distinguished road
Clutch / Engine
Okay I've got two noises I'm getting concerned about.
1. Squeky clutch pedal like friction/ resistance.
2. Just after the engine starts, it sounds like scratching or high pitched squek. I tried soap and water on the main belt and it didn't do anything.
Just looking for some ideas that might help
thanks
Old September 18th, 2006, 03:54 PM   #2
MikeyS281's Avatar
1999 Mustang GT
14.2 no mods, bald tires
MikeyS281 is on a distinguished road
Check your Idler pulley and your tensioner pulley for any play in the bearings or even change them out, they're cheap though. As for the sqeeky clutch, does it only make noise when the clutch pedal is totally let out? Does it stop when you push the clutch all the way in? If so then your problem is that you need a new throw out bearing. Let me know if this helps you any.
Once a Marine always a Marine!
Semper Fi Marines!
Old September 18th, 2006, 08:35 PM   #3
Havent had a chance to try the tensioner and idler but as for the specifics on the clutch noise it happens about half way to the floor board when i push it in, does not matter if the car is on or off.
Old September 19th, 2006, 03:38 PM   #4
MikeyS281's Avatar
1999 Mustang GT
Being that your clutch pedal sqeaks while the car is not running too then I would say check your linkagae and make sure it doesn't need to be greased, if that isn't it then you prolly need a new clutch that comes with a new throwout bearing and clutch fork.
Semper Fi Marines!
Old September 20th, 2006, 10:54 AM   #5
68 dlxcoupe's Avatar
2004 Mach 1
13.30 @ 104.47
68 dlxcoupe is on a distinguished road
Send a message via AIM to 68 dlxcoupe
I had the same problem with the noise when the car was off and it was my clutch i replaced it and it stopped. Its not a little job but try it and see hey if it doesnt work at least you get a new clutch lol :wink
Old September 22nd, 2006, 01:10 AM   #6
Replica R's Avatar
Replica R is on a distinguished road
Does the scratching noise happen while you are starting the car and then get louder when the car first turns on? If so it might be your starter. Mine is getting warped because my mechanic had to take if off so much to change my factory clutch, got tired of blowing my clutch and finally got a ram clutch.
Threads Similar to: Clutch / Engine
Clutch I need a clutch guru nHuman General Tech 2 September 22nd, 2009 06:12 PM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 11:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 03:33 PM
Will a 2002 Gt Engine Directly Replace a 2000GT engine? Bigb2000GT 99-04 7 April 22nd, 2007 06:09 PM
Clutch Prob When Engine Is Cold? WhiTeFoX5point0 5.0 Mustangs 7 November 21st, 2006 04:53 PM
