Look Ma! My First Post!
Throttle Body
Is there ne point in gettin a 65mm throttle body with the stock intake manifold???
1999 Ford Mustang V6
14.79 @ 92.15
no
I say go for it. I have a 2000 v6 I put a bbk 65 mm with my bbk cold air intake, and a throttle body spacer. And I'm impressed with the results of that mod
(2000 v6)bbk cai,motoblue udp,65mm throttlebody+spacer,diablo tuner, 4.10 gear,t-lok,160 thermostat, screamin demon, msd wires. bbk shorty headers, off road x,streetpro mufflers, Royal purple fluids, K&n oil filter. (89 5.0) msd dist,wires |
#4 | |
14.79 @ 92.15
I don't think I've lost power, I have that set up with underdrive pullies, 160 thermostat, diablo chip. Royal purple in every fluid (engine, trans, rear end) I just ordered my 4.10 gears with t-loc today. But I when I did the air intake and tb there was a noticeable increase, especially in the mid rpm range and sound of my engine. The chip made this even more noticeable. ( I wish I woulda went with another chip though I like the diablo chip, but would rather have the new sniper chip which you can do a custom tune from your computer from your mods, instead of paying a $100 for getting my diablo reprogrammed and dynoed. But there is alot I can do from my diablo on the user end, others can't.
I noticed that on your profile you have 4.10 gears, what kind of new kick can I expect from them coming from stock gears?
#7 | |
why didnt you get the SCT XCAL 2???
the major gain was the CAI, until you get into forced induction the tb doesn't impact any where near as what the upper and lower intake manifolds do. i would go with an intake manifold spacer rather than the tb spacer, elongating the intake runners will produce more power. great choice on 4.10s and t-lock that will give you the SOTP feel you are after.
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
the reason I went with diablo over sct, with diablo I can turn off my 02 sensors from the programmer and the sct doesn't have that feature listed. I want to get that pypes exhaust with the off road x pipe. I initally ordered the exhaust before my gears, but they sent me and e-mail temporarily sold out. So I just used that money for gears and t-loc
the XCAL 2 has to have that i think...idk i dont have it....yet
I will eventually get a the upper and lower intake manifolds, and replace the injectors with that. But I wanna get exhaust and lower the car down first. I already have 17x9 rims. But when I change the intakes I wanna change my cam, valve springs, rollers, timing chain. Stuff like that. And thats going to be awhile before I save that kind of money. Then get my chip reprogrammed for all that if I gotta pay $100 for it.
A good v6 mustang website is www.rpmoutlet.com Thats where I get most of my stuff They don't have cams or such, but a lot of good bolt on mods. (cold air, tb, chips, gears, maf sen, plugs,wires, tires, ignition systems, injectors, fuel pumps, lowering kits, clutch kits, subframe connectors, brake upgrades... etc Sometimes I wish my car was an manual instead of automatic
If you want a sct tuner, diablo, or sniper tuner at rpmoutlet.com if you enter their coupon id, they'll give you a 30.00 rebate and there prices are the same as other sites so you get a real discount. And they offer free next day air on all tuners.
yea rpm is good n im thinkin bout it, but mustangtunning has free shiipping and same price...free shipping is a big deal
at rpm they have a coupon code on there site you can easily find on the main screen that will give you an additional 30 off the 379 price and still free next day air shipping
next day air shipping free?!! get outta here? seriously?
check it out on their site I got the diablo chip with the $30 discount just type in the coupon code at check out, they have free next day air on all tuners. The diablo is $ 20 more I just figured you get what you pay for and I wanted the 02 disable. When you check out select the next day air option and it is free. Its on the promotion for it. I selected the next day air and it was there in 2 days. you can track your order online also from rpm.
Before you have your heart set on the sct, look at the sniper tuner I think you will like it
yea but what would make the sniper better then the SCT, ive really got my mind set on the SCT XCAL2...
is there any hp diff
instead on having to use the diablo tune you can modify on the tuner or the sct with specs you can modify also the sniper allows you to make as many custom tunes as you want for your car, as you get parts, all from your computer. You can tune 1 other car for free unlike other tuners. It still locks itself to your vin number.. But you can do one other car for free and buy sniper points to tune more cars for reletively cheap. Other tuners are a 1 car only. If you pull up 2 windows side by side the sniper tuner has more peramiters to tune making your engine run more efficiently
Compression ratio Low / High fan settings Engine idle speed Passive ati Theft Fuel Octane rating Headers / exhaust H / x pipe Rear oxygen sensor delete Trans shift points Trans shift firmness Engine rev limiter Engine speed limiter Tire height / speedo correction Gear ratio / speedo correction Air Fuel Ratio adjustments (richen/lean) Spark advance (+/-) and Same as normal features plus... Supercharger (Roots & Centrifugal) Turbocharger Nitrous (wet & dry) Injector size Returnless fuel pressure setting Fuel pump size setting Fuel pump type Mass Air brand / calibration Intercooler type Unlimited number of files can be created Unlimited performance files
Threads Similar to: Throttle Body
| Throttle Body | Snipe061 | V6 Mustangs | 8 | September 11th, 2007 04:28 PM |
| Throttle Body | autoranch | 96-98 | 4 | August 7th, 2007 09:24 PM |
| bbk throttle body | dumps | 2005 - 2010 | 4 | March 26th, 2007 08:02 PM |
| new throttle body? | AFtriathlete | General Tech | 18 | March 20th, 2007 01:14 AM |
| throttle body | noppe180 | 96-98 | 2 | November 4th, 2006 06:57 AM |
