#21 |
shoiuld i keep seperate shocks n struts
{Burn Rubber Not Your Soul}
#22 |
MM's official Chevy guy
if cost isent a obstical and u want the best praformance then get coil overs
![]() "Speak softly and carry a big stick" - Theodore Roosevelt "Any idiot can make a V8 fast, it takes a real idiot to make a fast V6". ![]() '02 Mustang N/A 4.3 stroker away for winter '72 Chevelle project car 454 coming '93 Bronco EFI 351W DD |
#23 |
ok so like what brand is best for the coil overs n the other stuff
#24 |
well im not shure i have been locking at them for a while and havent decided, but to me that disition u need to realy figer out what u want from ur car, meaning, a streat machine, auto-x, or drag
#25 |
You can't go wrong with Maximum Motorsports...
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles 2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP) 2001 Harley Davidson F-150 Acts 16:31 |
#26 |
its a street car
#27 |
ok well just a heads up, coil overs make for a much stifer ride, if u don't mide that then ya go for them, other wize stay with the stock style. and ya MM makes good stuf, that is streetable. but i also think the ebiaci (speeling) kit may not be to bad
#28 |
Coilovers can offer higher wheel rates (meaning, better handling) AND better ride quality at the same time.
#29 |
ok cool, so i need coilovers shocks n struts
#30 |
Just talk to Maximum Motorsports and they'll recommend a setup based on your intended use.
#31 |
ok but i wanna do it all while im at it springs shocks n struts. O n how much will i be able to lower it with 17 inch rims with a tires hight of atleast 40
#32 | |
So, a 275/40 is "taller" than a 245/40, for instance. With regard to how much you can lower the car. With coilovers, the height is VERY adjustable. Depending on the spring rate and spring length, you can generally lower it [safely] more than with conventional springs, but also adjust it heigher when/if necessary. BTW, you'll need C/C plates in order to use coilovers. Basically, it's not going to be cheap, but it'll be FAR superior to virtually any conventional spring setup.
#33 |
ok thanks
#34 |
1998 Mustang V6 5 spd.
These seem like a good deal.................
Eibach Springs Mustang Lowering Springs $130. |
#35 |
if i put coilovers in should i still put in other shocks n struts?
#36 |
Yeah, you'll still need new shocks and struts.
Like I said, it's an expensive setup: I'd expect to spend, oh, $1500+ on parts alone to go to Maximum Motorsports coilovers.
Threads Similar to: Lowerin
| lowerin car n decidin on new wheels n tires ?? | 4point6GT | 96-98 | 11 | June 13th, 2007 12:57 PM |
