Discussing What gives a 2005 and up V6 model more HP in the V6 Mustangs Forum. does anyone know how strong the blocks are in our cars? are they as well ...
Old February 13th, 2008, 11:31 PM   #21
tsp_2177's Avatar
2005 Civic
GAY!
are they as well designed as the 3.8l?
slow car member twinky times two
the stangs gone
pypes mid muffler catback with their X-pipe
In the top 20 cool peoples list on MM
potsticker in training
Old February 14th, 2008, 12:08 AM   #22
The Nice Guy
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
Originally Posted by Blainestang View Post
You're right that it's not part of the current "modular" family and that's it's a "Cologne" engine, but the current 4.0 is not a pushrod engine... it's SOHC. However, the Cologne family of engines have generally been pushrods.
no i am right on all terms. the 3.8 essex family is a SOHC pushrod and so is the 4.0. the 4.0 in the 05+ v6 is a SOHC pushrod.
ModdedAutos
1999 Mustang V6
Old February 14th, 2008, 12:16 AM   #23
Blainestang's Avatar
3.8L = OHV (Pushrod) = 1 Cam in block
4.0L = SOHC = 1 Cam per head (2 total)
1993 2.3L Coupe [Motortopia] : Open-Track Project... 214k miles
2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP)
2001 Harley Davidson F-150
Acts 16:31
Old February 14th, 2008, 12:22 AM   #24
SP00LIN V6
2000 Mustang V6
unknown @390
AB i hate to disagree here but Im pretty sure that 4.0L SOHC doesnt use push rods
the cam spins in the head and rides on something that pushes the valve down as the cam lob does.
i forget the name for it though
437rwhp and 402rwtq through a V6 on a stock bottom end
Old February 14th, 2008, 12:27 AM   #25
MM Phantom
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
... the ford mustang 4.0 colonge motor is a over head cam design though the block originated as a push rod engine... the engine was first altered in 97 when it was placed in the ford explorer as a 4.0 over head cam... though before this it was often used in smaller cars as a weak little V6 push rod engine
Back for brotherly love. My thoughts are with you Bubba!! [9-23-08]
Originally Posted by omz
Old February 14th, 2008, 12:30 AM   #26
SP00LIN V6
2000 Mustang V6
unknown @390
anyone have specs on this
im finding this hard to believe
an over head cam or cam in head motor does not use push rods as far as i know.
Old February 14th, 2008, 12:43 AM   #27
Followers/Rockers
I mentioned this in one of my earlier posts above...
It WAS a pushrod motor, but it was modified to now be OHC.
Originally Posted by Wiki
The original Ford Cologne V6, also known as the Ford Taunus V6, 640L, was a 60° cast iron block V6 engine built by the Ford Motor Company in Cologne, Germany, hence the name. It was closely related to the Ford Taunus V4 engine, adding two cylinders and no longer requiring a balance shaft. Over the years, the Cologne style V6 evolved from the engine displacements of 1.8, 2.0, 2.3, 2.4, 2.6, 2.8, 2.9 and 4.0 litres engines. All except the Cosworth 24v derivative and later 4.0 litre sohc engines were pushrod overhead valve engines, with a single camshaft between the banks. The Cologne V6 is still in production, is still a viable engine and does not closely resemble the original engines it evolved from. There is talk that it is scheduled to be replaced however Ford has made no formal announcement and recent news suggests it will remain in use in the Mustang as a base model engine into 2010. The new version of the Ford 4.0 L engine is listed as having 210 HP with 240 ft/lbs torque. Dyno tests by owners, and manufacturers of after markets products, have shown this engine to be underrated in reported HP.
Originally, the Cologne V6 was installed in cars intended for Germany and continental Europe, while the British "Essex" V6 was used in cars for the British market. Later, the Cologne V6 largely replaced the Essex V6 even for British-market vehicles. These engines were also used in the United States, especially in compact trucks.
The older fuel injected Cologne engine is lighter and more powerful than the equivalent Essex V6 even though its maximum engine displacement is smaller, but it produces less torque (Cologne V6 162 lb·ft (220 N·m) versus Essex V6 174 ft·lbf).
The Cologne V6 was made to be very compatible in installation with the Taunus V4, having the same transmission bolt pattern, the same engine mounts, and in many versions, a cylinder head featuring "siamesed" exhaust passages, which reduced the three exhaust outlets down to two on each side. The latter feature was great for compatibility, but poor for performance. The 2.4, 2.9 and 4.0 had three exhaust ports as in the photos, making them preferable.
The engine was available in both carburetted and fuel injected form.
Acts 16:31
Old February 14th, 2008, 12:59 AM   #28
SP00LIN V6
2000 Mustang V6
unknown @390
im not talking about what it was
im talking about the current 4.0L mustang having no push rods in it. just the followers or rockers
(thank you for reminding me)
Old February 14th, 2008, 01:36 AM   #29
SSStang's Avatar
2k2 Mustang V6
Talking
Your actually wrong.
The 3.8L essex v6 is an OHV pushrod motor...
The 4.0L colonge v6 is an SOHC motor
Selling for friend: Vortech Supercharge kit < 100miles.
Old February 14th, 2008, 08:26 AM   #30
The Nice Guy
14.79 @ 92.15
i stand corrected. the pushrod 4.0 was used in rangers until 2000... i thought that was the motor in the new mustangs, not the explorer one.
ModdedAutos
1999 Mustang V6
Old February 14th, 2008, 03:03 PM   #31
tsp_2177's Avatar
2005 Civic
GAY!
so the guy that ya'll flamed for his dyno sheets could have actually had those numbers huh?
the stangs gone
Old February 14th, 2008, 03:20 PM   #32
MM's official Chevy guy
whitemustang02's Avatar
2002 Mustang V6
no his numbers were still insane. they are hard enuf for a gt to get.
also he probed with other facts that he was just pulling shit out of his ass.
"Speak softly and carry a big stick" - Theodore Roosevelt
"Any idiot can make a V8 fast, it takes a real idiot to make a fast V6".
Originally Posted by Heather View Post
Me likey mikey
Old February 14th, 2008, 03:27 PM   #33
shadow5403's Avatar
2000 V6 Mustang
quote of the week is his stock injectors can handle up to 500HP
Old February 14th, 2008, 03:53 PM   #34
No.
Is the 4.0 slightly underrated? Probably... by about 10hp.
But either way, you can't UNDERRATE them once they're on the dyno, and I have SEEN dyno numbers for a 4.0 with bolt-ons and ported heads. It made a little over 200whp. This kid claimed to have 355whp with bolt-ons, the SAME ported heads, and higher compression pistons. Unless the pistons resulted in a 150whp gain (which they 100% absolutely did not), he was lying.
Acts 16:31
Old February 14th, 2008, 04:13 PM   #35
supercharged421's Avatar
2004 Mustang
n/a
turbos are usually more efficient then superchargers... though they are a tiny bit harder to work with/tune... either way your going to notice a nice gain when shoving 8-11 psi through that engine
your exactly right!
Old February 14th, 2008, 05:15 PM   #36
MM Phantom
Onemanzu's Avatar
i think its great that you guys are quoting wiki... very reliable
Old February 14th, 2008, 05:31 PM   #37
I wouldn't use it if my life depended on it, but it's in agreement with several other sources (including yourself) as it comes to the topic of it's previous valvetrain arrangement... so I thought it would suffice
Acts 16:31
Old February 14th, 2008, 06:01 PM   #38
2005 v6 Mustang
13.5
Listen The v6 motor witch is in the new mustang is aluminum Witch can nothandel as much as the Cast iorn like in the older six...
I think the older six was cast but I might be wrong....
But You can still bolt on a super charger and still pull greater numbers than the older Bitch ass 3.8 that mister mullit has
