3.73s In A 7.5 Rear... Will It Fit An 8.8
basically that ? up there
i plan on going turbo in the future..like next year, i wana buy gears but if i get the 3.73's now for my 7.5 rear, im pretty sure they're not going to fit the 8.8 rear that im going to need in the future.. please tell me im wrong if not then im thinking about gettting 4.10's for now....or just not wasting my money on it. also will the the t-loc on a 7.5 work for a 8.8
11.47@120.58
Would you expect a 7.5" ring gear to fit on an 8.8" carrier? You would need to swap the entire rear end.
1999 Ford Mustang V6
14.79 @ 92.15
yea dude, two completely different size rear end carriers
ok...it was a question
thnks for the replies tho
also i remember when i was able to ask a question and it not be answer in a smart remark or half ass
such as look for it yourself... and my post used to never get deleted...but shit i wonder who coulda done it right?
1984 GT
13.21@104.61
If you can do the work youself it wouldn't be a bad idea to put some 4.10 or 3.73 in your 7.5.
But if you need a mechanic it might be better to save you money for a 8.8 But as you are most likely aware your 7.5 may not hold up with your turbo. jjg
Eibach Sportsline, Mac, Moroso,Comp Cams,PRW roller rockers, and no money left over. |
#7 | |
Re: 3.73s In A 7.5 Rear... Will It Fit An 8.8
Chris, the size of the rear end (7.5, 8.8, etc) is the ring gear size so no, the carriers and gears are not are interchangeable. The axle shafts however are interchangeable between some 7.5 and 8.8 rear ends.
alrite thanks
since we're talking about an 8.8 rearend here, what parts would I need to build an 8.8 rear end. I'm looking at 28 spline axles, I have a 2000 gt posi trac, which I believe is a 28 spline axle posi trac. Would I need a drive shaft that is compatable with the posi trac or is there no difference. Also what other parts are needed? I'm looking at putting the suspension in at the same time as well.
![]() Friends Don't Let Friends Drive Rice! |
#10 | |
No I have nothing, I have a posi trac from a gt that a friend gave to me and that's it. What else do I need to complete this build up?
well I don't think this is what you meant but incase it is you can't make a 7.5" rearend into an 8.8" if that is what you are saying. you mean you only have the posi unit with no axle housing or anything, right?
yeah i know that it's not possible to make a 7.5 into an 8.8. What parts exactly will I need. I'm looking at making a 28 spline set up. I have a posi trac from a gt and that is it. What should be the first thing that I get and do you think it's cheaper to achieve an 8.8 rearend this way than buying one? What all exactly will I need to make one. Housing, axles, what?
Threads Similar to: 3.73s In A 7.5 Rear... Will It Fit An 8.8
| 8.8' Rear end vs. 9" rear end | jhooper | Classic Mustangs | 22 | April 25th, 2011 04:59 PM |
| Rear End | D-Brow | V6 Mustangs | 16 | April 18th, 2007 12:54 AM |
| What rear end? | ken5_0 | 5.0 Mustangs | 13 | March 20th, 2007 02:01 AM |
| Rear End | Pharoh | V6 Mustangs | 9 | February 16th, 2007 10:56 AM |
| Rear Rotors and Rear Axle | rondaw3g0410 | 99-04 | 1 | September 6th, 2006 11:00 PM |
