Discussing '99 Mustang Running Very Rough With Little Horsepower in the V6 Mustangs Forum. Not sure where to start. I have a '99 mustang, V6 with 120,000 miles. ...
Old October 4th, 2006, 09:11 PM   #1
Not sure where to start. I have a '99 mustang, V6 with 120,000 miles. When I crank the car it cranks fine, but now ides rough, and bogs down when accelarated. It cuts out pretty badly while driving. I have changed ou the fuel filter, spark plugs an wires. Not sure which direction to go. Would appreciate any help.
Old October 4th, 2006, 09:58 PM   #2
2003 Mustang GT
try cleaning your IAC valve, check for vacuum leaks, it could also be the coil pack.
70mm t/b, plenum, cast intake manifold, full magnaflow exhaust, JLT cai, FRPP c springs, anti roll kit, steeda upper control arms, custom tune, subframe connectors, HID headlights, mach 1 chin spoiler
Old October 4th, 2006, 10:39 PM   #3
Maintenance Man
mdvaldosta's Avatar
11.47@120.58
IAC valve doesn't affect anything when driving, only idling. If the car stumbles on acceleration it's usually ignition related. I'd check to make sure you don't have any dead cylinders, and if you do check for fuel and fire there. It may lead back to a bad coil as was suggested.
Old October 4th, 2006, 10:44 PM   #4
Modded Autos Site Mod
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
also check for seals on the intake manifolds. i had a similar problem after changing fuel filter, air filter, spark plugs/wires and even coil pack, and i had a leak at the back of my upper intake manifold- new gasket, perfection. check for vacuum leaks if you have good cyl. and use brake cleaner and spray around the manifolds, if the idle surges, you found the leak.
ModdedAutos
1999 Mustang V6
Old October 5th, 2006, 03:39 PM   #5
I had a scan done and it showed that #3 cylinder is dead, aslo it showed the #2 oxygen sensor was bad and the EGR flow was bad. What should i look for on the bad EGR flow?
Old October 5th, 2006, 04:32 PM   #6
14.79 @ 92.15
this is bad. you have no power in the 3rd cylinder.
you have a bad oxygen sensor which tests the air/fuel ratio and is making your car run weak as well, probably very rich. egr flow goes from the passenger exhaust manifold and recirculates into a pump and into the intake manifold
ModdedAutos
1999 Mustang V6
Old October 5th, 2006, 05:02 PM   #7
Re: '99 Mustang Running Very Rough With Little Horsepower
The condition of the sparkplugs is one of the best overall indicators on what is happening with your engine. Whenever I remove the sparkplugs I note which cylinder they came from and thier appearance.
2003 Mustang Mach1
1995 Thunderbird LX 4.6; 4R70W w/Jmod, 8.8 3.27 Tracloc
1995 Mustang 4.2; MPX Supercharger/25%OD, 4R70W w/Jmod, 8.8 3.73 Tracloc (343rwhp/420rwtq)
Threads Similar to: '99 Mustang Running Very Rough With Little Horsepower
Need help with rough running V-6 wildhorse V6 Mustangs 19 October 11th, 2007 12:43 AM
Running Rough 92mustanglx 5.0 Mustangs 5 April 6th, 2007 06:44 PM
97 GT Running Rough? rainbowmustang 96-98 5 March 21st, 2007 04:00 PM
Continuing saga of a rough running engine mickchu V6 Mustangs 3 January 28th, 2007 08:53 PM
rough running engine mickchu V6 Mustangs 9 January 24th, 2007 11:28 PM
