engine stumbles in drive and not in park!!!
Old March 11th, 2008, 10:18 PM   #1
2002 mustang
diesel88 is on a distinguished road
Send a message via AIM to diesel88
My mustang starts up perfect but when i put it into reverse or drive it revs up to 1500 rpm and then back down to 800 to 900 rpm. but if i go to mash the peddle down it starts to sputter really bad and slowly start to go. i have changed then coil pack, plugs, wires, air filter and mass air flow sensor and still the same problem. but i smell a weird burning type of smell when i get out of my car that seems like its coming from my cats, could my cats be clogged? should i gut them and see what happens then? please help i have only had this car for about 2 months and have had nothing but problems, its a 2002
thanks
joey
Old March 11th, 2008, 11:08 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
fouled cats= bad 02 sensors, they that and clean your IAC also check for a vacuum leak
NCMM #9
Old March 11th, 2008, 11:39 PM   #3
2002 mustang
no check engine light was on, i checked it anyways but no codes poped up. i can attempt to try to get new o2 sensors and see if that works, is there any way to test them to see if there bad? How do i check for vacum leak? whats a IAC and wheres that located?
Old March 11th, 2008, 11:41 PM   #4
MM's Resident Ricer
2006 Scion tC
13.001@113
idk of a way to check them usually they will smell like gas if they are bad but they dont always throw a code when they are failing,
what year is your car?
NCMM #9
Old March 11th, 2008, 11:43 PM   #5
2002 mustang
Threads Similar to: engine stumbles in drive and not in park!!!
Where do you park? Genevieve! The Clubhouse 114 March 2nd, 2008 05:47 AM
In park??? kerry Modular Mustangs 1 October 4th, 2007 10:18 AM
won't go into park JonnyB 5.0 Mustangs 2 July 7th, 2007 03:52 PM
2006 GT 4.6 Stumbles coming off the line red o6 2005 - 2010 19 March 25th, 2007 01:34 AM
car Idles really rough and stumbles tthrew all rpm rang gordon norris 5.0 Mustangs 9 February 11th, 2007 05:20 PM
